NEO 1X questions
0 Members and 1 Guest are viewing this topic. Read 1185 times.
bentconvert
NEO 1X questions
« on: 13 Dec 2008, 03:43 pm »
Hi all,
I am new to posting but have lurked around AC for awhile. My Neo 1X are almost complete and I have a couple of questions.
With when using NoRez what is a good starting amount of Acousta-Stuf to add to each enclosure?
The crossover drawing shows the high and low circuits separated until they reach the binding posts. Is this for clarification or is there a disadvantage to tying the two together at the crossover and running a common wire to the post?
Danny Richie
Re: NEO 1X questions
« Reply #1 on: 13 Dec 2008, 08:25 pm »
I like to create a loose fill of it filling most of the area in the box, especially right behind the woofer, but leaving a clear path to the port.
It is drawn that way for clarification and simplification. You can certainly tie them together at the crossover and use a single common wire leading to the binding posts.
