0 Members and 1 Guest are viewing this topic. Read 18997 times.
I hope this post helps you out in your Open Baffle Project.Sincerely,Mark K
Quote from: markk on 3 Feb 2009, 06:48 amI hope this post helps you out in your Open Baffle Project.Sincerely,Mark KHi Mark,I've been looking at a good wideband driver for mids to highs and the Hemp seems very nice. Besides padding the whizzer, did you feel the need to do other interventions on it?You're running it fullrange, without filters, right?Also, IB15 vs OB15. Using only one woofer per speaker which one would you choose?
I have been using the Hemptone FR8 for almost a year now and have been very impressed with them considering their price of approx $128.00 each. I have not had a chance to hear the more expensive lowthers so I guess I do not know what I am missing.(...)I do not know much about the OB15. I do not see it listed on the AE website store.I was also thinking about building a Dipole speaker in the future with only one of the IB15 Drivers per side and trying to make the width of the baffle a bit narrower.The Hemptone website seems a bit messed up right now and I have not been able to click on the specs of the two drivers like I used to. I suggest you give them a call and see if they can send the specs of each driver to you.
