Would this also provide surge protection like the Tripp Lite Isolation Transformers?
Do you have any larger units?
Does it use Faraday shielding?
Hello,At the moment, no. We recommend using separate units for digital and analog equipments, thus the smaller capacity unit was designed.ThanksDavid
Any updates on a larger version? The problem is that your unit isn't big enough for one mono block.
Sorry, still no plans on higher powered units.
Hello:I have a new fender Blues jr. guitar amp, 15 watts. I have an issue with noise in this amp. While a certain amount of noise is expected, I am finding way more than normal and have related it to some lighting, and other audio equipment.Would your Isolation Transformer help reduce the noise in this amp?Thanks, Harrison
