4B-ST replacement faceplate and handles and BCD-1 laser lens cleaning
0 Members and 1 Guest are viewing this topic. Read 2482 times.
nikon
What is the approximate cost for a 4B-ST replacement faceplate and handles
Is the laser lens in the BCD-1 glass or plastic and what is the recommended method for cleaning same
nikon
Sorry, I should have included this in the first post ...
Can the C series faceplates be retrofitted to the 4B-ST and BP-20 (with an MPS-2)
  • The Demo is Everything!
    • http://www.bryston.com
Hi Nikon,
Faceplates for the 4B are $200 and the Handles are $100 the pair.
No sorry the SST C-Series can  not  be retrofitted on the ST Series.
Yes the BP20 can be retrofitted with the C-Series faceplate only if used with an MPS-2.
I will check on the lense question for you.
james
vegasdave
James, are you still able to replace the damaged faceplate on my 4BSST? Is this covered under the warranty? It came that way when I received it.
I brought this up to you a while ago, if you can remember...
Hi Dave,
Yes please contact Mike Pickett at Bryston.
james
vegasdave
Do I have to ship the entire amp in...what is Mike's email, please. Thank you.
[email protected]
nikon
Mr Tanner
Thank you for your reply
Did you determine if the laser lens in the BCD-1 is glass or plastic and the recommended method for cleaning same
