0 Members and 3 Guests are viewing this topic. Read 381929 times.
Here is the give and take on my helpdesk dialog with antelope re: USB Class 1 and 2:Regarding your questions about USB modes and Classes:USB mode,classes and versions are 3 totally different things.UH1 mode is Called USB Class 1 because its compliant with USB Audio Class1 (not to be confused with USB VERSION 1.0)UH2 mode is Called USB Class 2 because its compliant with USB Audio Class2 (not to be confused with USB VERSION 2.0)so in general terms USB Class 1 IS NOT USB Version 1.0 and/or USB Class 2 IS NOT USB Version 2.0Thank youBest regards!1 Days Agotedmbrady -- Yesterday, 1:30 PMThanks. I fully understand the differences between USB Class 1 and USB Version 1.0. But isn't it true that USB Class 1 support is only up to 24/96 and 12Mbits? UH1 goes significantly higher.5 Hours Ago techsup (Antelope) -- Today, 8:07 AMDear Ted,again USB Class is totally different from USB "Version".So in USB 1.0 you get the 24/96 12Mbits/Sec. But USB Audio Class 1 can be used either in USB 1.0 or USB 2.0.[/b]I'm not sure I agree with their definitions; maybe it's me.
Nick, et al,Here is Antelope's response to USB Audio classes:Dear Ted, as for USB Audio Classes:Well there isn't actually any Standards for this (Audio Class Transfer Rates and everything), so we can transfer 192Khz,480Mbits/Sec through USB Audio Class 1.0 (through some "secret doors" let's say). It is the same way as transferring 384Khz-480Mbits/Sec through USB Audio Class 2.0. We still can do that also!
I might have an opportunity to acquire a Sokeris board for a very decent price. This board differs from the alix 2d2 and 3d2 as it has a PCI slot. Should I try a Juli@ PCI card or one of the Asus sonar cards. They both will do 24/192 analog out. I was curious to see how well it sounded compared to my QB-9. The whole kit would be under $300.Anybody interested in hearing it? I could arrange for some kind of pass around within the group.
For folks that are thinking of running the Alix on Battery, I have some observations....Currently mine is run on the same supply as a DODD Buffer and a Class D amp. When I just ran the Alix with the DODD, I thought I did not have any added noise. As it turns out, there was a little high-pitched whine if the DODD was turned up a LOT.
I had a Juli@ for a while in my main PC and was impressed by the sound. The Bryston BDP-1 seems to be doing well (getting good reviews) using it and Voyage.Which Soekris board are you looking to get?
But are you thinking of using the analogue out of either card?
Will the Audio GD Digital Interface work with the Alix box? I am currently running a John Keny Modified Boxed HiFace MKII. As most of you already know, the M2Tech drivers don't like Linux based stuff.http://www.audio-gd.com/Pro/dac/USBface/Digital1EN.htm
It does work. The device has some kind of USB mixer so you have to remember to set its volume to 100% max for best sound quality.
Hi Nick,I may be interested in this, or at least what others find out, but foir a slightly different reason. I've now got an Audiophilleo AP2 converter to use with my AudioGD NFB-2, so I'd still use USB for the dac interface, but I'm wondering if there is a firewire 800 card that would work in the slot on this new board, and that way a self-contained linux based music player could be built quite economically -- something that may be a lot easier for some folks to deal with since they won't have to fret too much about network files, etc. May even possibly be a performance jump as well.-- Jim
Nick,Yes, so it could be a stand-alone box with local storage in the form of an external FW drive. Much like I'm running my mac mini right now.Problem is that there seems to be a number of variations on the pci slots and I really can't tell the differences between them and which cards will work in what kinds of slots, and of course I don't know what type of slot is on this new board.
Nick,Problem is that there seems to be a number of variations on the pci slots and I really can't tell the differences between them and which cards will work in what kinds of slots, and of course I don't know what type of slot is on this new board.
