0 Members and 4 Guests are viewing this topic. Read 382059 times.
^^^I actually tried that and it gave this...Stopping Music Player Daemon: mpd.Starting Music Player Daemon: mpdcreating /mnt/tunes/mpd/tag_cache... ... (warning).listen: bind to '0.0.0.0:6601' failed: Address already in use (continuing anyway, because binding to '[::]:6601' succeeded)Failed to load database: Failed to open database file "/mnt/tunes/mpd/tag_cache": No such file or directorydatabase: Can't create db file in "/mnt/tunes/mpd": Permission denied failed!
preadet,would you be willing to post your successful fstab file contents? I've still been unsuccessful to get my windows share mounted.not sure if it will help but I'd doublecheck that the directories you are specifying in mpd.conf are all created properly. I had failed to create a directory path properly. Once I did that, even though I couldn't connect to the share drive, mpd fired up OK. I'm new and may be totally wrong but figured I'd offer something up.
I'm playing!I made 2 changes. 1, the Database file is not with the music anymore, it is on the Alix, and 2, I commented out the user setting.
How about this? I had to set the user to "root" but everything is on the server now and it is working...I have yet to have "remountro" give me a result other than mount: / is busymusic_directory "/mnt/tunes"playlist_directory "/mnt/tunes/mpd/playlists"db_file "/mnt/tunes/mpd.db"log_file "/mnt/tunes/mpd/mpd.log"pid_file "/mnt/tunes/mpd/pid"state_file "/mnt/tunes/mpd/state"user "root"bind_to_address "any"port "6601"metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"input { plugin "curl"}audio_output { type "alsa" name "Music Fidelity V-Link" device "hw:0,0"}buffer_before_play "100%"filesystem_charset "UTF-8"id3v1_encoding "UTF-8"follow_outside_symlinks "yes"follow_inside_symlinks "yes"zeroconf_enabled "yes"zeroconf_name "Voyage Music Player"mixer_type "hardware"
All the files are now on the NAS, that is what I posted above. I just had to set the user in mpd.conf to "root"I have never been able to tell the Alix to remountro. Always the same error.Any ideas where to get the DC plug for the back on it's own?
You can set the Alix for static ip in /etc/networking/interfacesExamples: http://www.google.com/search?hl=en&source=hp&biw=1296&bih=652&q=debian+static+ip&aq=1&aqi=g10&aql=&oq=debian+staBut, if you were goint to install ddwrt, I would. I've heard it's much more stable than the stock firmware.
NFS client and ALSA are already installed. Remaining steps are:1. Configure your NAS to export your music directory.2. Configure ftsab file on alix to mount NFS or CIFS share on your NAS.3. Edit mpd.conf
My Alix is now on Battery power!Here is the cord with the added switch...It is on the same Battery as an Amp and a Dodd Buffer and I have no Noise that I can detect...
