0 Members and 4 Guests are viewing this topic. Read 382231 times.
as far as I can see, I have no option of fixing the MAC of the server to an IP in DHCP on my router.
I'm looking at the PDF for that router now, give me a few minutes...
What do you see when you goto Setup, then Basic Setup page, then Network Setup section and click on the Advanced button?Or, http://192.168.1.1/dhcp_reserved.asp
404 Not FoundFile not found.I am familiar with DHCP. I am pretty sure the router lacks this option
In mine I am able to go into the DHCP connections table and override a DHCP assigned address to a "static setting" with the address of my choice, in range. It is quite hard to find, like an advanced menu. I searched your manual but couldn't find any. Maybe hunt around those screens to see if there is a sneaky edit that's not so obvious. Were you not able to mount the CF card and just edit the file?
I was, but must have made an mistake, because it did not work properly. After I tried this, I just reinstalled the cf again and started using DHCP again. Now I am having new issues. My voyage is telling me that mpdmusic and mpdplaylist are not directories. Well... they were and they still are.... must be something with permissions...
What do you mean by "my voyage"? Is it an mpd error? Can you browse the directory from the command line?
ok, I fixed the permissions and I can see all mounted dirs again. Latest problem is mpd -start-create.db is telling meroot@voyage:~# /etc/init.d/mpd start-create-dbStarting Music Player Daemon: mpdcreating /mnt/nfs/mpd/tag_cache... ... (warning)..all help is welcome... I don´t mind playing around with linux, but while doing that... I want to hear some music playing..
I am able to create files in the mounted dir...logged in as root and su to another user, both worked
I tried both,root@voyage:~# mpd --create-db** ERROR **: option parsing failed: Unknown option --create-dbaborting...Aborted
You're not able to play any music? No Do you music files show up in the mpd client? Yes Is your mpd client able to connect to the mpd daemon? Yes
I am assuming that an iTouch would make a nice remote for one of these.Would this device work as what you boys have been building? Would run about $155 or so, built and delivered.http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=280532916633&ssPageName=STRK:MEWAX:IT
