0 Members and 3 Guests are viewing this topic. Read 382210 times.
There is no switch on the Alix to allow it to be powered down (which is the only way you could turn off the USB AFAIK). You could add a power switch, the Alix takes less than a minute to boot.Best,Ed
You guys are killin' me with this. Can the USB port be turned on / off? I don't want the dac to always be on.
Do you use static ip adresses for you Alix? How do you set these?I tried via the ethernet connection, but this failed. Do I need to restart all over again to get my access via dhcp back?
Yes I used static addresses for pretty much everything here. 2 ways to do it. Either set it for eth0 on the Alix using the command ifconfig (temporary) or in /etc/network/interfaces file on boot. The other way is to just fix it to the mac address in the router, which is what is suggested.If you do it on the command line just use both commands on one line to take it down and back up without losing your session, e.g. "ifdown eth0 && ifup eth0" will bring it back on the new address.
Fixing the static IP to the MAC adress is no option in my router. So I have to do this on the Alix. Is there an easy way to connect again? As far as I can see it has no adress now
Mount the compact flash card on another linux server.
Do I run into problems with permissions, because of mounting the cf to another system?
I've been away on a mini vacation...If you mount the CF card on another Linux machine, mount it as root so that you'll have full access.If you want to log in via the serial console, you'll need a serial cable and a null modem adapter, or a serial cable that is wired as null.For a newbie, might be just easier to mount the card on another linux box and make the changes.
I mounted the CF to another linux system and reinstalled the CF to make sure it works. I will try to create another CF to test with a static IP in a few days. I tried to put the static address in /etc/network/interfaces, but I must have made a mistake, because it did not work. Not pingable from any other station.
Linksys WAG54GS
