0 Members and 3 Guests are viewing this topic. Read 382236 times.
Hi, does Alix support Windows-7? I've found a lite version of Win7, there is only 3.71GB after intallation, and if closed the virtual memory, there is 2GB left, so if Alix support Win7, it will be a good news for peoples like me who are not familiar with Linux.
Hi, does Alix support Windows-7? I've found a lite version of Win7, there is only 3.71GB after intallation, and if closed the virtual memory, there is 2GB left, it's easy to put into a 4GB CF card, so if Alix support Win7, it will be a good news for peoples like me who are not familiar with Linux.
There are a lot of resources to help you with Linux if you want to give it a go....its not a big investment at $125.
Thanks. I am pretty good at Windows Audio, Linux will be my future plan.
Thanks to Nick, I'm up and running with my ClearOS 5.2 file server and Voyage MPD on Alix via USB to my Bryston BDA-1 (unfortunately only 24/44.1). I'm using Minion on Firefox as the client for now and it seems to work great.Now I just need to come up with a Linux compatible 24/192 USB converter ...Thanks Nick!!!
installation looks a bit hairy on on OSX but I see it supports last.fm. Any way to get Pandora?
No problem. Try the gmpc client, you might like it: http://gmpc.wikia.com/wiki/Gnome_Music_Player_Client
Installed this on XP laptop and it is VERY cool. Locked up a couple times. This would be really nice on an iPad or another tablet device...
So to get Minion to tell MPD to stream do I need to add an output to mpd.conf? I streamed some tracks via gmpc on the XP machine, I could see what had been played on the Minion playlist on my Macbook, but can't figure out how to just start it from Minion. I know, more Google... sorry, I'm still learning.
I can play from my library of ripped files. Just wondering how to point it to a url/stream such as internet radio source.
You guys are killin' me with this. Can the USB port be turned on / off? I don't want the dac to always be on.
