Dead silent dedicated Linux music server for USB DAC's.
0 Members and 4 Guests are viewing this topic. Read 382507 times.
ebag4
Re: Dead silent dedicated Linux music server for USB DAC's.
« Reply #100 on: 24 Sep 2010, 07:09 pm »
Hi ebag4,
Does Ubuntu see your USB DAC in the sound configuration applet?
Yes it does, however when I pick it and run test a window pops up and says:
audiotestsrc wave=sine freq=512 ! audioconvert !
audioresample ! grconfaudiosink profile=music:
Could not open audio device for playback
I have never had an issue getting it to play in Windows.  I was thinking I had an issue in my MPD configuration files but after looking at this more closely I am thinking the issue may lie elsewhere.
Best,
Ed
edit:when I run asoundconf list I do not see my DAC, only the on-board sound and the word default
« Last Edit: 24 Sep 2010, 08:31 pm by ebag4 »
nyc_paramedic
« Reply #101 on: 24 Sep 2010, 10:21 pm »
Best,
Ed
Can you paste you mpd.conf file here? Do you have alsa-utils installed? If so, what do you see when you type 'aplay -l" with your USB DAC plugged in? Is the DAC 16 bit or 24 bit? Also, what version of mpd are you (type mpd --version) running?
ebag4
« Reply #102 on: 24 Sep 2010, 11:30 pm »
Thanks Nick, I appreciate any insight you can offer.  My Havana is a 16 bit DAC but it has never had a problem playing 24 bit files.
EDIT: I decided to let Ubuntu do an upgrade that it was nagging about.  MPD and Sonata still work as they were before, however when I go to the Sound preferences panel the whole setup has changed.  I no longer see my DAC there, now all that is there is a internal audio choice and a Turtle Beach card that is not even installed.
EDIT 2: Ubuntu is seeing my USB DAC as the Turtle Beach unit but it doesn't call it a USB DAC.
Best,
Ed
Here is what aplay -l shows:
root@linux:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: I82801DBICH4 [Intel 82801DB-ICH4], device 0: Intel ICH [Intel 82801DB-ICH4]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: I82801DBICH4 [Intel 82801DB-ICH4], device 4: Intel ICH - IEC958 [Intel 82801DB-ICH4 - IEC958]
  Subdevices: 1/1
card 1: default [USB Sound Device        ], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
root@linux:~#
and this is my mpd.conf:
# An example configuration file for MPD
# See the mpd.conf man page for a more detailed description of each parameter.
######################## REQUIRED PATHS ########################
# You can put symlinks in here, if you like. Make sure that
# the user that mpd runs as (see the 'user' config parameter)
# can read the files in this directory.
music_directory      "/home/ed/Music/nmt"
playlist_directory   "/var/lib/mpd/playlists"
db_file         "/var/lib/mpd/tag_cache"
log_file      "/var/log/mpd/mpd.log"
error_file      "/var/log/mpd/errors.log"
######################## OPTIONAL PATHS ########################
# If you wish to use mpd --kill to stop MPD, then you must
# specify a file here in which to store MPD's process ID.
pid_file      "/var/run/mpd/pid"
# If specified, MPD will save its current state (playlist,
# current song, playing/paused, etc.) at exit.  This will be
# used to restore the session the next time it is run.
state_file      "/var/lib/mpd/state"
######################## DAEMON OPTIONS ########################
# If started as root, MPD will drop root privileges and run as
# this user instead.  Otherwise, MPD will run as the user it was
# started by.  If left unspecified, MPD will not drop root
# privileges at all (not recommended).
user                            "mpd"
# The address and port to listen on.
bind_to_address                 "any"
port                            "6601"
# If the address is a path, then a UNIX domain socket will be
# created instead of listening on a TCP port.
#bind_to_address                 "/var/run/mpd/sock"
# Controls the amount of information that is logged.  Can be
# "default", "secure", or "verbose".
#log_level                       "default"
########################### ZEROCONF ###########################
# If yes, service information will be published with Zeroconf.
#zeroconf_enabled                "yes"
# The service name to publish.  This name should be unique on
# your local network.
#zeroconf_name                   "Music Player"
########################## PERMISSIONS #########################
# MPD can require that users specify a password before using it.
# You may specify one ore more here, along with what users who
# log in with that password are allowed to do.
#password                        "password@read,add,control,admin"
# Specifies what permissions a user who has not logged in with a
# password has.  By default, all users have full access to MPD
# if no password is specified above, or no access if one or
# more passwords are specified.
#default_permissions             "read,add,control,admin"
########################## AUDIO OUTPUT ########################
# MPD supports many audio output types, as well as playing
# through multiple audio outputs at the same time.  You can
# specify one or more here.  If you don't specify any, MPD will
# automatically scan for a usable audio output.
# See <http://mpd.wikia.com/wiki/Configuration#Audio_Outputs>
# for examples of other audio outputs.
# An example of an ALSA output:
audio_output {
         type                    "alsa"
         name                    "HAVANA"
         device                  "hw:0,0"     # optional
#        format                  "44100:16:2" # optional
# An example of an OSS output:
#audio_output {
#        type                    "oss"
#        name                    "My OSS Device"
#        device                  "/dev/dsp"   # optional
# An example of a shout output (for streaming to Icecast):
#audio_output {
#        type                    "shout"
#        encoding                "ogg"                   # optional
#        name                    "My Shout Stream"
#        host                    "localhost"
#        port                    "8000"
#        mount                   "/mpd.ogg"
#        password                "hackme"
#        quality                 "5.0"
#        bitrate                 "128"
#        format                  "44100:16:1"
#        user                    "source"                # optional
#        description             "My Stream Description" # optional
#        genre                   "jazz"                  # optional
#        public                  "no"                    # optional
#        timeout                 "2"                     # optional
# An example of a null output (for no audio output):
#audio_output {
#        type                    "null"
#        name                    "My Null Output"
# Force all decoded audio to be converted to this format before
# being passed to the audio outputs.
#audio_output_format             "44100:16:2"
# If MPD has been compiled with libsamplerate support, this
# specifies the sample rate converter to use.  Possible
# values can be found in the mpd.conf man page or the
# libsamplerate documentation.
#samplerate_converter            "Fastest Sinc Interpolator"
############################# MIXER ############################
# MPD needs to know what mixer settings to change when you
# adjust the volume.  If you don't specify one here, MPD will
# pick one based on which ones it was compiled with support for.
# An example for controlling an ALSA mixer:
mixer_type                      "alsa"
mixer_device                    "default"
mixer_control                   "PCM"
# An example for controlling an OSS mixer:
#mixer_type                      "oss"
#mixer_device                    "/dev/mixer"
#mixer_control                   "PCM"
# If you want MPD to adjust the volume of audio sent to the
# audio outputs, you can tell it to use the software mixer:
#mixer_type                      "software"
######################### NORMALIZATION ########################
# Specifies the type of ReplayGain to use.  Can be "album" or
# "track".  ReplayGain will not be used if not specified.  See
# <http://www.replaygain.org> for more details.
#replaygain                      "album"
# Sets the pre-amp used for files that have ReplayGain tags.
#replaygain_preamp               "0"
# Enable on the fly volume normalization.  This will cause the
# volume of all songs played to be adjusted so that they sound
# as though they are of equal loudness.
#volume_normalization            "no"
########################### BUFFERING ##########################
# The size of the buffer containing decoded audio.  You probably
# shouldn't change this.
#audio_buffer_size               "2048"
# How much of the buffer to fill before beginning to play.
# Increase this if you hear skipping when changing songs.
#buffer_before_play              "10%"
# Similar options for the HTTP stream buffer.  If you hear
# skipping while playing HTTP streams, you may wish to increase
# these.
#http_buffer_size                "128"
#http_prebuffer_size             "25%"
########################### HTTP PROXY #########################
# Specifies the HTTP proxy to use for playing HTTP streams.
#http_proxy_host                 "proxy.isp.com"
#http_proxy_port                 "8080"
#http_proxy_user                 "user"
#http_proxy_password             "password"
############################# LIMITS ###########################
# These are various limits to prevent MPD from using too many
# resources.  You should only change them if they start
# restricting your usage of MPD.
#connection_timeout              "60"
#max_connections                 "5"
#max_playlist_length             "16384"
#max_command_list_size           "2048"
#max_output_buffer_size          "8192"
###################### CHARACTER ENCODINGS #####################
# If file or directory names do not display correctly, then you
# may need to change this.  In most cases it should be either
# "ISO-8859-1" or "UTF-8".  You must recreate your database
# after changing this (use mpd --create-db).
filesystem_charset              "UTF-8"
# The encoding that ID3v1 tags should be converted from.
id3v1_encoding                  "UTF-8"
######################### OTHER OPTIONS ########################
# Try disabling this if you have MP3s which appear to end
# abruptly.  If this solves the problem, it is highly
# recommended that you fix your MP3s with vbrfix (available from
# <http://www.willwap.co.uk/Programs/vbrfix.php>), at which
# point you can re-enable support for gapless MP3 playback.
#gapless_mp3_playback             "yes"
# Enable this if you wish to use your MPD created playlists in
# other music players.
#save_absolute_paths_in_playlists "no"
# A list of tag types that MPD will scan for and make available
# to clients.
metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
nyc_paramedic
« Reply #103 on: 25 Sep 2010, 02:37 am »
If your DAC has a 16 bit chip then ALSA is down-sampling 24 bit files on the fly to 16 bit before they get sent to the DAC.
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
root@linux:~#
Your USB DAC, as per aplay -l above,  is card 1, device 0. And you need to tell MPD that. Below in your mpd.conf you have hw:X,Y where both are set to zero, i.e., card 0, device 0. Change it to what is listed in aplay -l, i.e., hw:1,0, also known as card 1, device 0.
After you do this or make any change to mpd.conf you must restart mpd via /etd/init.d/mpd restart.
Let me know of that helps.
audio_output {
         type                    "alsa"
         name                    "HAVANA"
« Last Edit: 6 Oct 2010, 08:27 pm by nyc_paramedic »
ebag4
« Reply #104 on: 25 Sep 2010, 02:52 am »
Nick, you ROCK!  Thanks for the explanation and the fix, much appreciated.  Applied your fix and it is now cranking out tunes via USB.
Best,
Ed
nyc_paramedic
« Reply #105 on: 25 Sep 2010, 04:03 am »
Keep one thing in mind for the future: If you do upgrade to a true 24bit USB DAC and you're using a version of mpd that is *prior* to 0.16, you have to change the "hw" part in hw:X,Y to plughw:X,Y
mpd versions 0.15 and older do not support 24 bit packed samples, so using plughw will "pad" your 24 bit files with zeroes, if I remember correctly. 'Tis not the same as re-sampling.
ebag4
« Reply #106 on: 8 Oct 2010, 03:14 pm »
I am about to dive in.  My Alix, power supply (ultimately I plan to use my Optima Battery), case and CF card should be here today.  I will probably be hitting you up for troubleshooting Nick.  I just received my Tranquility DAC last week so I am anxious to hear the pairing.
Best,
Ed
jrebman
« Reply #107 on: 8 Oct 2010, 03:30 pm »
anxious to hear the pairing...
Ed, I'm also looking forward to your impressions on this pairing.
Good luck,
Jim
nyc_paramedic
« Reply #108 on: 8 Oct 2010, 06:02 pm »
... Nick.  I just received my Tranquility DAC last week so I am anxious to hear the pairing.
No problem.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #109 on: 8 Oct 2010, 06:22 pm »
As an update: I have had some trouble getting NFS working. So hope to have that fixed soon, next week...
I tried to use nfs from mac mini with osx as server, to the alix as client, but gave up. So I wiped the apple mini and installed debian. That seems to work, but editing my mpd.conf file is not cooperating.
-Tony
nyc_paramedic
« Reply #110 on: 8 Oct 2010, 06:26 pm »
What trouble are you having with mpd.conf?
ebag4
« Reply #111 on: 8 Oct 2010, 06:58 pm »
Received my Alix, this thing is tiny!
Unfortunately the Voyage Linux site is not responding.  Nick if you or Jim or Tony could email the Voyage file I need I would appreciate it.  I do have a Voyage linux 6.5 iso file but I don't know if I can use that or not.  I seem to be getting off to a great start!  :lol:
Best,
Ed
TRADERXFAN
    • GALLERY
« Reply #112 on: 8 Oct 2010, 07:00 pm »
Well, the file was blank. I used vi to edit. I followed the script on the blog of what it should say. I typed in all of the the non "#" areas that I needed, but it won't write to the file. Tried several times, after making sure the cf was mountrw. I checked that I was able to do other things on the card. Now my plan is to make a new file, write the info to it, then make it the mpd.conf file. Hopefully that does it. If not, going ot try and remove the mpd and then do a new install of it.
-Tony
TRADERXFAN
    • GALLERY
« Reply #113 on: 8 Oct 2010, 07:03 pm »
Best,
Ed
Are you following the instructions from the blog?
http://cheap-silent-usb-linux-music-server.blogspot.com/
I printed it out.
then I took a red pen and numbered the steps, starting from the bottom, but you should follow what Nick says. I had to alter what I did a bit from that blog.
-Tony
ebag4
« Reply #114 on: 8 Oct 2010, 07:07 pm »
Hi Tony,
I tried the link from that blog as well as a gogle search, they both sent me to the same place.  Unfortunately the site is not responding.
Best,
Ed
TRADERXFAN
    • GALLERY
« Reply #115 on: 8 Oct 2010, 07:19 pm »
PM'd you my email. Email me and i will send you the blog info and nick's advice on what to do a little different.
-Tony
jrebman
« Reply #116 on: 8 Oct 2010, 07:20 pm »
Ed, sorry, I don't have it.
-- Jim
ebag4
« Reply #117 on: 8 Oct 2010, 07:55 pm »
Tony, I received your email, thanks.
Jim, no worries, thanks anyway.
Nick, can I use the instructions from the blog if I am using Ubuntu instead of Debian?  I was able to get the CF card formatted!! WOOHOO! :lol:
BTW, Nick, if you have access to the Voyager tar file and can email it to me please let me know, I wil send you my email address.  The Voyager HK site may be back up later but I am unable to bring it up right now.
Best,
Ed
nyc_paramedic
« Reply #118 on: 8 Oct 2010, 09:17 pm »
The Voyage site is down as the maintainer is moving to a different server.
The instructions are not really valid for Ubuntu without midification. It's vey specific to Voyage Linux. The Voyage Linux README and/or install script will take care of formatting the CF card for you.
I'm at work now, but I'll see if I have the .tar file when get home tonight --around midnight.
TRADERXFAN
    • GALLERY
« Reply #119 on: 8 Oct 2010, 09:20 pm »
Once you are ssh'd into the Alix, the formatting directions should all be the same. The configuration of the desktop computer are the parts that are likely to change... [although I am no help with any of that]
