0 Members and 1 Guest are viewing this topic. Read 4180 times.
Could this have something to do with the Brits operating at 220 volts and the USA at 110 volts?
Quote from: Wind Chaser on 3 Dec 2008, 05:00 amCould this have something to do with the Brits operating at 220 volts and the USA at 110 volts?Well, yes ... if speaker drivers were driven by AC mains directly!
Maybe the British feel that their watts, like their currency, is superior to the American counterparts.
It's really quite simple.The British, and our Canadian cousins are now using Metric Watts, while here in the US we still use Imperial Watts.Use of the Metric System is also the reason why Britain and Canada are colder than here in the States!As you can see, that really wasn't so hard to explain. Best Regards,TerryO
I wonder of the impedance curve is in American Ohms or British.
So a "watt" isn't a "watt" and an "ohm isn't an "ohm" leaving everything unknown. As a Canadian I find this very perplexing because we are stuck in the middle being part of the British Commonwealth and yet at the same time undeniably influenced by our neighbors to the south. I propose Canadian watts and Canadian ohms as a compromise.
Quote from: Kevin Haskins on 4 Dec 2008, 02:12 amI wonder of the impedance curve is in American Ohms or British. So a "watt" isn't a "watt" and an "ohm isn't an "ohm" leaving everything unknown. As a Canadian I find this very perplexing because we are stuck in the middle being part of the British Commonwealth and yet at the same time undeniably influenced by our neighbors to the south. I propose Canadian watts and Canadian ohms as a compromise.
