High quality jumper cables
0 Members and 1 Guest are viewing this topic. Read 2590 times.
jwes
« on: 2 Dec 2008, 09:28 pm »
Hi all,
Does anyone have a suggestion for some high quality jumper cables?  I have bi wire speakers (2 sets of posts) and a good new set of speaker cables.  They don't make jumpers, and I'm concerned with using just a pedestrian set of jumpers between the two binding posts.  This is a rather generic request because I'd use any - the highest quality I can get...
Thanks!!
rydenfan
Re: High quality jumper cables
« Reply #1 on: 2 Dec 2008, 09:30 pm »
Synergistic Research makes really nice jumpers, and I remember them being pretty reasonably priced.
PhilNYC
« Reply #2 on: 2 Dec 2008, 09:34 pm »
I would check to see if the company that makes your speaker cables makes a matching jumper...
jwes
« Reply #3 on: 2 Dec 2008, 09:43 pm »
Thanks David, I'll look into Synergistic Research.
PhilNYC, unfortunately they (ASI) don't make jumpers at this time...
WG
« Reply #4 on: 2 Dec 2008, 10:26 pm »
Gregg Straley, Reality Cables, just did some jumpers for me as well as speaker cables.  If you have a Class-D amp, you might want to speak with him on his heavier white wire option, both for speaker wire and for jumpers.  This wire option is not shown on his website.  This is the first time I have worked with him and have been quite pleased with the results.
Will
rydenfan
« Reply #5 on: 2 Dec 2008, 10:58 pm »
Will
What is the difference between this wire and his standard wire? and why does Class D matter?
WG
« Reply #6 on: 2 Dec 2008, 11:23 pm »
Gregg's standard cable has two wound wires per terminal end, total of 4 per each wire pair.  The option wire has one thicker wire per terminal end, total of 2 per each wire pair.  The standard jumpers are bound together in the + & - pair.  The option jumpers are individual wire terminations.  I do not know if there is a difference in the actual wire material.
Gregg sent me a set of both to try on my speakers.  Each of my speakers have a separate driver panel and woofer module, so I alternated connections from left and right and then panels and drivers over a few days.  The option wire for me had more detail and more forward in presentation.  Bass impact seemed greater and more resolved as well with this wire.
Gregg was the one saying this wire has had positive response with only Class-D, but did not find it was nearly as suitable with other amps.  I would only be making guesses why he makes those specific suggestions, but he is good about answering his emails.  He can be called as well, but recommend after 5:00 PM his time--CST in Illinois.
Will
rydenfan
« Reply #7 on: 2 Dec 2008, 11:40 pm »
Interesting. Thanks for the reply.
ted_b
« Reply #8 on: 3 Dec 2008, 12:50 am »
My jumpers that i use in my Mundorf external crossovers for the Elrod Remote Sense cables are Gregg's jumpers, married to some bananas.  (The SR Tesla biwires's had their own, of course.)
TomS
« Reply #9 on: 3 Dec 2008, 01:06 am »
I used Gregg's Reality jumpers (red) as an alternative to the stock Cardas ones on my Merlin VSM-MX's with great success.  They are nicely made and Gregg was very responsive as usual.
Christof
« Reply #10 on: 3 Dec 2008, 01:31 am »
Shameless self promotion follows....
I have a set of Anti-Cable jumper that you can have for $10 + shipping, PM me if interested.
c.
jwes
« Reply #11 on: 3 Dec 2008, 01:47 am »
Wow.  I clearly need to check out this Gregg character  :thumb:
Ted it sounds like you invested well in one run and then went with jumpers, which is what I'll need to do...  Thanks for all the suggestions folks!  :)
This is of course not to shut it down... please send other ideas!
  • Speakers....What Speakers ?
« Reply #12 on: 3 Dec 2008, 05:23 am »
Well then....here's the link..... :thumb:
2gumby2
« Reply #13 on: 3 Dec 2008, 12:20 pm »
I have the Anti-cable jumpers with banana connectors. I can enthusiastically recommend them. Excellent service also.
