Source for wire spring bananas?
0 Members and 1 Guest are viewing this topic. Read 1165 times.
James Romeyn
« on: 19 Nov 2008, 11:28 pm »
Seeking source for banana plugs w/ single lengthwise wire for tension vs. the ubiquitous multi-leaf.  The only ones I've seen were decades ago on Naim cables, nickel plated finish unimportant.
Configuration unimportant: singles, standard 3/4" spaced duals or, if such exist, spaced 1-5/16" for international components.
Bob in St. Louis
Re: Source for wire spring bananas?
« Reply #1 on: 19 Nov 2008, 11:39 pm »
Hey Jim,
Do you mean these?
{Scroll about two pages down}.
Hope that helps,
Bob
James Romeyn
« Reply #2 on: 19 Nov 2008, 11:48 pm »
No, but thanks anyway Bob.
I'll dig up a picture & post if I find one.  The ones I'm wanting seem like the best bananas because of the way the single lengthwise wire maintains tension.  I guess I disfavor the locking Monster bananas because of the extra spade termination required on the speaker wire.
Bob in St. Louis
« Reply #3 on: 19 Nov 2008, 11:53 pm »
Ok, one last shot Jim.....How about these?
Bob
EDIT: ack! The link isn't going to the right page....  :duh:
Bob in St. Louis
« Reply #4 on: 19 Nov 2008, 11:55 pm »
Ok, try this page
James Romeyn
« Reply #5 on: 20 Nov 2008, 12:17 am »
Nope!
Here it is, at least in gold:
Note the single lengthwise tension wire.  IMO you'd never return to split multi-blade types after trying these.  One NAIM dealer has them in nickel but $5ea per polarity, ouch!  They are Deltron brand from England.
What type of pin connectors do you like for the newer binding posts that take only bananas, bare wire or pins?
jmc207
« Reply #6 on: 20 Nov 2008, 01:42 am »
I've got a set of XLO cables that came with banana's like these. Wonder if they are available separately from XLO?
bacobits1
« Reply #8 on: 20 Nov 2008, 03:12 am »
These work very well. Just finish them off with colored shrinky. :lol:
http://www.audio-magus.com/product_p/mcls4.htm
Den
James Romeyn
« Reply #9 on: 20 Nov 2008, 03:29 am »
The last two mentioned both look great.  I emailed Acton to see if they ship to USA.
Thanks much for both suggestions!
The only banana mentioned at XLO is a dual-snap-together banana.  Looks like a single wire spring but can't tell for sure.
jmc207
« Reply #10 on: 20 Nov 2008, 03:47 am »
I found these single Deltron banana's at XLO. Look just like what you have pictured above. Unfortunately, I have no idea who sells these things or at what price. My only Google hit on the part # was for some Polish web site.
http://www.xloelectric.com/products/DB/DB.html
