Matching Speakers for 4B SST
0 Members and 1 Guest are viewing this topic. Read 14157 times.
Tosko
« on: 17 Nov 2008, 10:17 pm »
Hi everyone!!
What of the following speakers match perfect (or very very well) using a 4B SST ?
1) Monitor Audio (Gold Signature Series) GS 20  or  GS 60
2) Energy Veritas 2.3 i
3) B&W 603 S3
4) B&W 703 or 705
5) Focal 800 Series.
6) Paradigm Reference Signature
Or.... :duh:...what speakers recommend me (in the same price range) for that lovely amp ??
Thanks.
jethro
Re: Matching Speakers for 4B SST
« Reply #1 on: 17 Nov 2008, 11:42 pm »
Tosko:
I'm not sure about pricing but you might want to listen to the PMC TB1 or PMC FB1.
I'm not sure if they still make them, but the B&W 805 might work well.
Magnepans also sound good with the 4B (I'm not sure of the pricing).
HTH, Steve
Brown
« Reply #2 on: 18 Nov 2008, 12:10 am »
Hi everyone!!
3) B&W 603 S3
4) B&W 703 or 705
Thanks.
 None. Maggies are very good.
john1970
« Reply #3 on: 18 Nov 2008, 01:06 am »
Hi everyone!!
3) B&W 603 S3
4) B&W 703 or 705
Thanks.
Tosko,
If you already have the 4B SST I would recommend taking the amp to the dealer and testing the amp with the above speakers.  I use a Byrston 4B SST with a pair of VMPS RM40 speakers and I am very content with the sound.  Better yet, if the speakers are small (bookshelf) the dealer might let you audition them in home.
Good luck,
John
vegasdave
« Reply #4 on: 18 Nov 2008, 09:47 am »
I use JBL Studio L890s...it's great combo, imo.
I'd say the 4BSST can drive all of those speakers you mentioned.
Tosko
« Reply #5 on: 18 Nov 2008, 08:13 pm »
Tosko:
HTH, Steve
Thanks 4 your answer Jethro (Steve).
The point is that in my country (Argentina) does  :nono: not exist distributor/reseller of that excellent brand (PMC).
I´d listened the B&W 805´s but......it seems have not tight and controlled bass and don´t have a neutral sound (IMHO).
Thanks.
Tosko
« Reply #6 on: 18 Nov 2008, 08:24 pm »
Hi everyone!!
3) B&W 603 S3
4) B&W 703 or 705
Thanks.
Tosko,
If you already have the 4B SST I would recommend taking the amp to the dealer and testing the amp with the above speakers.  I use a Bryston 4B SST with a pair of VMPS RM40 speakers and I am very content with the sound.  Better yet, if the speakers are small (bookshelf) the dealer might let you audition them in home.
Good luck,
John
Thanks for your answer John.
I don't have the 4B SST yet. But when I get it, I´ll take the amp to the dealer and I will spend much time listening the above speakers. I hope I´ll make a good choice.
Thanks again.
Tosko
« Reply #7 on: 18 Nov 2008, 08:28 pm »
Hi everyone!!
3) B&W 603 S3
4) B&W 703 or 705
Thanks.
Thanks 4 your answer Brown.
In my country (Argentina) does not exist distributor/reseller about Maggies. Only Martin Logan.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #8 on: 18 Nov 2008, 08:29 pm »
Hi Tosko,
How big is your room and what kind of music do you listen to?
james
PS - Also what speakers have you used in the past?
Tosko
« Reply #9 on: 18 Nov 2008, 08:33 pm »
Tanks for your answer vegasdave.
I found the JBL´s sound (in my personal taste) too bright. IMHO.
Tosko
« Reply #10 on: 18 Nov 2008, 08:46 pm »
Hi Tosko,
james
Hi again James.
Thanks for your answer.
My room: 4 metres (width) x 7 metres
Music: Stevie R. Vaughan, B.B.King, Tom Waits (he´s amazing), Queen, John Pizzarelli, Pink Floyd, D. Krall, Norah Jones,  Ella Fitzgerald,  Pearl Jam, Iron Maiden, AC /DC, Charly García, and... many many so....
I still use a B&W 603 S3 speakers
« Reply #11 on: 18 Nov 2008, 09:00 pm »
Hi Tosko,
james
Hi again James.
Ok - And your saying you do not like the B&W's in your current setup?
What amp are you using?
james
Tosko
« Reply #12 on: 18 Nov 2008, 09:15 pm »
Hi Tosko,
james
Hi again James.
james
I´m using a Marantz SR 7300 receiver + Denon 2900 Universal player+ 603 S3 +LCR 60 S3
I like my B&W 603 S3. Thus I´m trying to buy a 4B SST, I´m looking for speakers that plays in the "same league of the 4B SST". James, we know that 603 S3 line is a entry level and 4B SST is a reference amp (at least in my budget)
vegasdave
« Reply #13 on: 18 Nov 2008, 11:02 pm »
You're welcome. No problem. Which JBL models have you heard?
rob80b
« Reply #14 on: 18 Nov 2008, 11:25 pm »
I'm running a pair of small Dynaudio Contour's but it's hard to imagine the 4BSST not doing a stellar job with the majority of speakers, small or large.
Robert
Toronto
Tosko
« Reply #15 on: 18 Nov 2008, 11:42 pm »
I don't remember wich models I´d heard. It was in 2003 (5 years ago). But... I heard Northridge line (I did not like them). About the Studio Line  I´d  heard bookshelf (Studio 80 or something I don't remember) Good speaker but too bright to me.
Tosko
« Reply #16 on: 18 Nov 2008, 11:53 pm »
Robert
Toronto
Thanks 4 your interesting Robert.
I think the same that u think. (The 4B SST is amazing)
But ones match 4B SST better than others.....Im looking for transparency and a touch of warm....
Kindest regards from Buenos Aires.
Brown
« Reply #17 on: 19 Nov 2008, 12:16 am »
Robert
Toronto
Sorry I gave such a short kurt reply. What i meant that out of the speakers you mentioned none would be a good as the Maggie Bryston combo. Vandersteens are warm and transparent. The 2ce and 3a are fine speakers. good luck looking.
Tosko
« Reply #18 on: 19 Nov 2008, 01:40 am »
Robert
Toronto
Don´t worry Brown. Thanks 4 all.
alexone
« Reply #19 on: 19 Nov 2008, 05:27 am »
Hi everyone!!
3) B&W 603 S3
4) B&W 703 or 705
Thanks.
hi,Tosko!
what price range are these speakers you mentioned?
i assume that you are using the pre outs from your Marantz receiver, correct?
if so then don't forget the necessity of a matching preamp. another ac member just wrote that he bought a used BP20 to drive his Bryston amp and it really blew him away!
good luck and happy listening! :thumb:
al.
