*SOLD* DIY Pass Mini Aleph
0 Members and 1 Guest are viewing this topic. Read 8468 times.
strhd07
« on: 17 Nov 2008, 05:29 pm »
OK, don't believe me. When I got one of Tim Rawson's Mini Alephs, it sounded so good that when a real-deal Aleph 30 came along, I thought it must sound better and bought it. Well, I liked the Mini mo' bettah and ended up selling the 30. (I've seen one or two other people also say they preferred the Mini to the original.) If you don't need the extra power of the 30 and can make do with 15 watts, this is one of the shweetesht amps you'll hear, and that's coming from a long-time tubophile.
Here's what Mr. Rawson his own self told me when I bought the amp: "It's basically an Aleph 3 using one pair of output fets and a little lower voltage but also some of the front-end improvements (like input impedence) of the Aleph 30. Of the four Alephs I've tried, Mini, 3, 30, and 5, I like mini and 30 best."
I have two of these fellas, so one's got to go. I sent Tim a set of WBT binding posts to install, and at my request, he drilled some holes in the bottom of the chassis, since these suckers run hot in Class A. This one also comes with an LED power light, which Tim's amps usually don't have. For those of you unfamiliar with Tim's work, the beauty is in the insides; the outsides of his projects are a bit rough and ready.
$350. Paypal add 3%. Please PM if you're interested.
« Last Edit: 9 Dec 2008, 12:10 am by strhd07 »
JoshK
Re: DIY Pass Mini Aleph
« Reply #1 on: 17 Nov 2008, 05:34 pm »
Love the purest looks.  :thumb:
strhd07
« Reply #2 on: 17 Nov 2008, 05:39 pm »
Hey, a thick slice of good roast beef and a couple slabs of bread make a sandwich. You don't worry about how pretty it is once you've tickled your stomach with the taste.
anubisgrau
« Reply #3 on: 18 Nov 2008, 08:42 am »
anyone tried mini aleph vs F3? pros & cons?
satfrat
« Reply #4 on: 18 Nov 2008, 09:09 am »
Sure would be nice to take a look inside? :drool:
Robin
anubisgrau
« Reply #5 on: 18 Nov 2008, 09:12 am »
ah, there's not much to see with nelson amps - a power tranny, PS board and 2 ouput boards....everything really small:)
kck
« Reply #6 on: 18 Nov 2008, 02:51 pm »
I have compared an F3 with my Aleph mini-J. The Rawson amp won handily, which puzzled me no end. Now of course they are different topologies so that's the first gotcha.
Not that the F3 was bad, but it was sorta laid back and didn't light up the music the way the Rawson does. And no, I don't like bright sound; this is a different thing.
anubisgrau
« Reply #7 on: 18 Nov 2008, 03:41 pm »
but is the mini aleph with J-FETs or not? not sure if the unit for sale is aleph-J? it would be good to clarify this...
anyway, sthrd07 you have mail (not PM)
thanks
kck
« Reply #8 on: 18 Nov 2008, 07:08 pm »
thanks
See the second paragraph from sthrd07's original post.
strhd07
« Reply #9 on: 22 Nov 2008, 02:45 pm »
Lions and tigers and BUMP.
A weekend nudge before this toddles down the Yellow Brick Road to Audiogon.
strhd07
« Reply #10 on: 8 Dec 2008, 04:19 pm »
Bump, widda new pic of the innards.
Wind Chaser
« Reply #11 on: 8 Dec 2008, 04:37 pm »
Any chance you know what the input impedance and sensitivity is?
strhd07
« Reply #12 on: 8 Dec 2008, 05:26 pm »
No, I don't. As it says in the description, the amp is basically a 3 with some features of the 30, including input impedance. There should be info out there, both at Pass and for the Mini, that gives specs.
