0 Members and 1 Guest are viewing this topic. Read 12116 times.
Dennis,I thought I was able to get in room response (EQ'd via a TacT unit) into the mid 20's with my HT3's.In terms of bass below 25Hz, my Vandy 5A's do that in room, but they are way more expensive than the HT3's and achieve that with a powered woofer.George
George. Sorry but I am very confused by your various posts. Do you still have the HT3s, Vandy 5A's AND the EP CS2's? How would you rate all of these speakers?TIA!
Big challenge for the HT4 to be better than the HT3, wouldn't you think?
I know these records very well but they sounded so much more alive and reach out and touch it dimensional that it was scary exciting.
One caveat. I think there could have been a little more flesh on the bone in the lower treble, upper mid range. Don't know if this a characteristic of the speaker or how spread apart they were from where I was sitting.
Can you please describe the components of AliG's setup please.
QuoteCan you please describe the components of AliG's setup please.Moscode 301 amp with Telefunken smooth plates.
Correct me if I'm wrong but I think the area just behind G's equipment racks and between his speakers is recessed, too. That's G's good luck, I think. Like it's a bay window or something (couldn't tell for all the treatment).
And I think those Salk ribbons are definitely a step up in quickness, maybe extention, too, from my domes.
QuoteCorrect me if I'm wrong but I think the area just behind G's equipment racks and between his speakers is recessed, too. That's G's good luck, I think. Like it's a bay window or something (couldn't tell for all the treatment).Yeah, I would bet that back space enhances things. I was able to achieve the same kind of thing by putting my speakers on perpendicular walls, creating a triangular field receding behind them. I fully agree that well treated small rooms can produce great results, like being at the podium or in a front row seat at the night club. If AliG can achieve that with two TC subwoofers I don't feel so crazy trying it with my 2-way monitors (my room is only 11x12 or so), which aren't exactly mini-monitors. I'm sure he has significantly more absorption than I do.
That is insane....People.... I need some good links into room treatment.Stuff to look for and where.RegardsHP
