Question concerning the SP1.7 and surround modes..
0 Members and 1 Guest are viewing this topic. Read 4563 times.
DefTechFreak
« on: 21 Nov 2003, 03:19 am »
First I'd like to say Hello to everyone, as I am new here and will be a Bryston owner soon.  :D
I am in the market for a pre/pro and have been looking at the Rotel 1098, the Ati 7500 and 8500.1, but then the Bryston caught my eye.
What I need to know is...
Does the Bryston take 5.1 and 6.1 material and add the 7th channel like other pre/pros do? Does it do this for all movies? Or will I get the 7.1 ONLY with discs that are truly 6.1?
I know if I get the Rotel, that I will have 7.1 for all my movies, regardless if they are true EX/ES discs..I am praying the SP1.7 does this, and I am hoping that someone in here can help me out.
I downloaded the manual and it doesn't get very specific. I saw that in the setup, it indeed has back left and right surrounds, but I don't want to jump the gun on this.
Thanks for reading and I look forward to any and all responses.  :mrgreen:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 22 Nov 2003, 07:54 pm »
Hi Def,
I think I answered this one for you from our website - correct?
james
DefTechFreak
« Reply #2 on: 23 Nov 2003, 01:41 am »
Yes sir you did...and Thanks  :mrgreen:
jgubman
« Reply #3 on: 2 Dec 2003, 07:33 pm »
What was the answer? :)
DefTechFreak
« Reply #4 on: 2 Dec 2003, 08:34 pm »
The answer went something like this.
There are 3 settings for back surrounds...
Auto
On/Yes
Off/No
If you have back surrounds, and want them used All the time, regardless of what surround mode is used, use the On/Yes setting. If you want them used only when certain movies have the required flags, and would use them better, then the Auto feature is used.
If I screwed this up, I apologize.  :o
I will use the ON feature. If ya got back surrounds, I say use 'em!  :D
jgubman
« Reply #5 on: 2 Dec 2003, 08:52 pm »
Yeah, makes sense. There's no special name for the back speaker processing (ala Logic 7 or Circle Surround)? What's the processing involved on getting 7.1 channels out of a 2 channel source? Are the rears a matrix of the side surrounds, or something fancier?
« Reply #6 on: 2 Dec 2003, 08:58 pm »
Please see my attached Newsletter - this is the official setup at recording studios - try to get as close to this as possibble.
http://www.bryston.ca/newsletters/65_files/vol6is5.html
james
DefTechFreak
« Reply #7 on: 2 Dec 2003, 10:16 pm »
Thanks for the link James  :)
jgubman
« Reply #8 on: 2 Dec 2003, 10:18 pm »
Yeah, the newsletters are great!
Do you mail/email those newsletter when they're produced, or does one just regularly check the web site for updates?
« Reply #9 on: 3 Dec 2003, 12:51 pm »
HI,
If you want I have a data base called Bryston News on which I email all new Newslettters. Usually about 6 a year.
Just send me your email address and I will add it to the data base.
james
jimmyp58
« Reply #10 on: 3 Dec 2003, 10:42 pm »
Count me in James --- please add me to your database.  E-mail address is:
[email protected]
Thanks....
