***SOLD***Emotiva MPS-1 7 channel amp
0 Members and 1 Guest are viewing this topic. Read 1419 times.
Big Red Machine
« on: 6 Nov 2008, 08:16 pm »
On-line description:
http://emotiva.com/mps1.html
 Audiophile quality, modular power amplifier
• True card cage design can accommodate up to seven 200 watt (@8 ohms) mono block power modules - power modules glide in and out on Nylon rails
• 200 watt power modules feature independent 350VA low noise toroid power transformers w/ high speed rectifiers and low ESR 105°C power supply capacitors
• High efficiency Class H power amplifier design, minimizes power losses and allows cool operation
• Complementary, discrete power amplifier design incorporating high current, high speed, Toshiba power devices
• Truly transparent, integrated soft clip circuitry
• Balanced XLR and RCA inputs
• Channel status indicators for standby, operate, and fault
• THD less than .015%, 20Hz-20kHz with 80kHz measurement bandwidth
• DC offset, less than 1mv, servo controlled
• Completely Stable into 2 ohm loads
• 200 watts/8 ohms – 300 watts/4 ohms – 400 watts/2 ohms - seven channels driven, mains limited
• Frequency response 20Hz-20kHz +/- 0.1 dB, or 10Hz-125Khz +/- 3dB
• Signal to Noise Ratio - 100dB, un-weighted
• Input impedance - 20k ohms
• Crosstalk between ANY channels – greater than 120dB
• Fully protected from all fault conditions with ultra quiet, module mounted, fan assisted cooling for severe duty cycle applications
• Soft start circuitry. Silent turn on/off - No audible transients
• Signal sensing auto turn on or remote trigger Soft touch power switch
• All aluminum capacitors are premium quality, low ESR, 105°C rated for high reliability and performance
• Doubled sided, plate through, glass epoxy, FR4 PCB’s used throughout with 2 ounce poured copper on all power sections and ground planes
• Modules are designed for field replacement with the removal of four screws
• 4RU chassis with floating multi-element, milled aluminum faceplate. Indirect cobalt blue illumination of all controls and main panel
• Black lacquered, piano finished wood side panels are included, as are milled aluminum rack ears for professional installations
• Massive, multi element milled aluminum faceplate with "floating” wing detail – indirect, cobalt blue panel illumination with panel dimmer
• Power consumption during standby – 3 watts or 60 watts at idle
• IEC power inlet, 120/230 VAC user configurable on modules
• 5 year warranty
• Weight - 115 lbs
• Dims: (HxWxD) 7 11/16” x 18 7/16” x 18 7/8"
I have the original boxes for safe transport.
If I recall these were in the $2000 range when new.
Asking $1150 + shipping.
About to install 3 Wyreds across the front 3 speakers in the HT so this is up for sale.
« Last Edit: 13 Nov 2008, 08:12 pm by Big Red Machine »
Big Red Machine
Re: Emotiva MPS-1 7 channel amp
« Reply #1 on: 8 Nov 2008, 11:41 pm »
7 channels, 7 blades. Wink2
Big Red Machine
« Reply #2 on: 10 Nov 2008, 08:23 pm »
Bump.  Packed and ready to go!!! :thumb:
