VPI Aries 3 with Gingko Cloud 11
0 Members and 1 Guest are viewing this topic. Read 3223 times.
fsimms
« on: 30 Oct 2008, 07:35 pm »
AliG loaned me his Gingko Cloud 11 isolation platform to try under my VPI Aries 3 turntable.  I was amazed at the difference that it made.   The background was blacker, the pops and clicks were greatly reduced and the voices and instruments crystallized out of the fog.   I can also play music at a much higher level without distortion.   As Michael Fremer says, "the difference wasn’t subtle" .
I have a greatest hits album by Ray Charles and with my old Nottingham Horizon turntable with an AT OC9 cartridge; it sounded OK but not great.  Playing it on my Aries 3 on the Cloud with the same cartridge, it almost brings me to tears because it is so beautiful.
jpv
Re: VPI Aries 3 with Gingko Cloud 11
« Reply #1 on: 31 Oct 2008, 01:42 am »
Fsimms,
    While I don't have the Gingko Cloud I found the same experiance with a sandbox.
The sandbox is filled with 75 lbs of sand with a 3" thick platform. I found that tables with no suspension need isolation of some sort. I have a scoutmaster and before I placed it on the sandbox I experianced the same problems. Like you said blacker backgrounds, low level detail comes thru, bass cleaner.
tnewell
« Reply #2 on: 31 Oct 2008, 02:36 am »
I love the Gingko Cloud 11 under my Scoutmaster.  Best of all the tweaks, even better than the Super Platter.
Tom
AliG
« Reply #3 on: 31 Oct 2008, 03:05 am »
Tom,
  Did you actualy try the Super Platter on your Scoutmaster? I'm serious thinking about getting it.
barry
Tom
twitch54
« Reply #4 on: 31 Oct 2008, 12:57 pm »
Good news, for you to notice the improvement you mentioned in "pops and clicks" you must have had some serious isolation issues I suspect.
Nothing like a good tweek to make things that much better !!
tnewell
« Reply #5 on: 31 Oct 2008, 08:20 pm »
I do have the Super Platter.  I need to update my system info and pics.  The Super Platter did improve the sound greatly. Bass is much tighter and backgrounds much quieter.
I should probably rephrase my statement on the Gingko.  For the money, the Gingko was the best upgrade for the Scoutmaster.  The Super Platter is a great upgrade but will run you $1,200.00
Hope this helps.
Tom
AliG
« Reply #6 on: 31 Oct 2008, 08:55 pm »
fsimm, knowing how you like the Gingko Cloud 11, I am going to raise the price to $500!! :banana piano: :banana piano:!!!!!
lazydays
« Reply #7 on: 1 Nov 2008, 07:08 pm »
I did the sandbox as well as the Ginko Cloud on the same table with the same arm. The Ginko is better in almost everyway but cost. I might add that there are a couple tricks to make the Ginko sound better yet.
gary
fsimms
« Reply #8 on: 2 Nov 2008, 01:09 pm »
What are they?
Bob
