I think there are too many complex surface shapes and transitions around the top/baffle junction.
The top surface should make one smooth curve down towards the front, with this curve transitioning to the same radius as the sides of the baffle before reaching the front. This would have the dual function of dissuading the use as a support for potted plants.
I think the bottom of the baffle should have minimal rounding - it looks awkward looking down as in the top picture.
The top port is a great idea, but the edge needs not to be an edge - it'll break too easily. This design would make easy a port refinement that usually is too awkward to implement - a variable length. If the opening were not straight across but had a V shape (that is, further from the front in the center, or like an arrow pointing aft) the tuning would be slightly smeared across a frequency range which might be to advantage, but at least makes good copy! If done right, this would make it more difficult to use it as a handle.
