Speaker connection problem 9BSST
Tony1
« on: 30 Oct 2008, 02:14 am »
I went to change my speaker cables today and had a problem tightening the speaker cable behind the 9B.  I use spades so when I went to tighten the terminal the plastic part terminal was just turning making a grinding like sound but the terminal would not tighten on the spade.  This only happened to 2 of them, the rest tightened up.  Is something broken or stripped? I haven't changed my cable since I bought the amp 3 years ago. Any suggestions?
Tony
  • The Demo is Everything!
    • http://www.bryston.com
Re: Speaker connection problem 9BSST
« Reply #1 on: 30 Oct 2008, 10:15 am »
Tony
Hi Tony,
If it just spins then it sounds like it was overtightened and got stripped.  I will pass this on to Mike at Bryston to be sure.
james
Tony1
« Reply #2 on: 4 Nov 2008, 08:27 pm »
James
Have you heard from Mike?  Am I able to replace it?
Tony
« Reply #3 on: 4 Nov 2008, 11:02 pm »
James
Tony
Hi Tony,
I did pass it along - I will check tomorrow.
james
Tony1
« Reply #4 on: 13 Nov 2008, 12:18 am »
James
Any news from Mike?
Tony
« Reply #5 on: 13 Nov 2008, 12:51 am »
Hi Tony,
Yes I did pass it along - I am surprised Mike has not contacted you.
I will get on it.
james
« Last Edit: 13 Nov 2008, 03:18 pm by James Tanner »
« Reply #6 on: 13 Nov 2008, 07:08 pm »
HI Tony,
I checked with Mike and he says the 2- channels or the amplifier will have to come into service.
james
