Neo-2X TL Tower
0 Members and 1 Guest are viewing this topic. Read 4264 times.
Bill Baker
    • Musica Bella Audio
Re: Neo-2X TL Tower
« Reply #20 on: 2 Nov 2008, 06:50 pm »
I'm thinking of bleaching this crazy waterfall quilted bubinga and throwing a dye stain on it
I'm thinking the same thing. I would really love to see it. :drool:
but I just don't know
 I do. I'll make the decision for you...... JUST DO IT :green:
Hank
Re: Neo-2X TL Tower
« Reply #21 on: 3 Nov 2008, 01:00 pm »
Hank originally drew up the plans.
Yes, I designed the tower cabinet for Al's RAV-6 kit, for which Danny designed the crossover and supplied his M165X woofer.  My CAD design was two versions:  rear slot port and front slot port.  I highly recommend the rear port for front baffle clean look.  You only have to have a foot and half or two foot clearance behind the cabinet.
