How would I know if I need bass traps?
0 Members and 1 Guest are viewing this topic. Read 8887 times.
woodsyi
Re: How would I know if I need bass traps?
« Reply #20 on: 12 Nov 2008, 04:41 pm »
Hey Woodsyi...  that big panel looks like a bass panel not a diffusor....Is it a diffusor that covered with fabric?   I'm probably just confused as usual.
Rob S.
Yes,
It's a big (to me) diffuser covered in fabric I got from Alan at SRL Audio.
http://www.srlaudio.com/product_pdfs/4ft_tall_X_6fft_wide.pdf
srlaudio
    • SRL Acoustics
« Reply #21 on: 13 Nov 2008, 05:47 pm »
Yeah woodsyi,
    Don't forget the "large" diffusors at the early reflection points.....and the parts you don't see....extruded aluminum mounting hardware (no wires!) and solid construction that required a helper to carry down the stairs and mount.  All of this at breakthrough pricing.  I will NEVER sacrifice performance for a lower price....
woodsyi
« Reply #22 on: 13 Nov 2008, 06:04 pm »
Oh yeah,
I have 2 3' x 4' x 9" SRL diffusers at the first side reflection points too.
Of course I also have 10 Real Traps, 4 GIK panels and 4 8th Nerve corner Adapts deployed in the room along with hidden battings above the drop ceiling.  Every piece contributes to the whole in my opinion.
satfrat
« Reply #23 on: 13 Nov 2008, 06:31 pm »
Oh yeah,
I can now see why you'd be interested on the Acoustic ART System woodsyi. :lol: FWIW, my room's no better looking visually, you do what you gotta do with what you got to do it with and I'm doing it with a combination of acoustic products from 8 different companies. :thumb:
Robin
Rob S.
« Reply #24 on: 13 Nov 2008, 06:43 pm »
Woodysi,
      did you put batting above the entire drop ceiling?  I did just my room perimeter, as it was very time consuming stuffing 15in of fiberglass batting around all those metal grid pieces.  Then I did 4  2' x 4' ceiling tiles from Ethan in the sweet zone.
Do you think entire ceiling coverage of batting above the drop ceiling makes ceiling tiles not necessary?
Rob S.
woodsyi
« Reply #25 on: 13 Nov 2008, 07:26 pm »
Woodysi,
Rob S.
Rob,
Like you, I did the perimeter with strong emphasis on the corners.  I don't think you need to do the whole ceiling.  There are cables and pipes running through there as well as the wires holding the drop ceiling grid.  I am not doing the middle portion. :nono:
Isn't it amazing how much R 38 batting you can stuff into a corner?  :lol:
dyohn
    • the12volt.com
« Reply #26 on: 13 Nov 2008, 08:44 pm »
You need to use traps if the little buggers keep getting away.
 :duh:
