RAD Sub12 with 350W amp and LT circuit
0 Members and 1 Guest are viewing this topic. Read 8733 times.
Brian Bunge
« on: 18 Nov 2003, 04:06 pm »
OK, here's the first frontfiring sub that I've done with a 12" driver, 350W amp, and LT circuit.  The enclosure is a 15" cube with an internal vertical brace and 1.5" thick baffle.  You'll notice in the picture that I still need grill guides in the top two holes but they should be here any day.  I just wanted to share pics of the sub at this point in time.
Hank
« Reply #1 on: 18 Nov 2003, 04:25 pm »
Brian, is that the result of your pre-built sub thread, or is it a new, lower-cost product idea experiment?  I assume the latter because the plate amp looks like a PE - or is it a Rythmic?  Anyway, I like the size and it should be an shoe-in for the WAF :wink:
Hint:  can you add some light to your photos?
Brian Bunge
« Reply #2 on: 18 Nov 2003, 04:27 pm »
Hank,
It's a Rythmik amp and is the result of the "prebuilt sub" thread.
george king
« Reply #3 on: 18 Nov 2003, 04:53 pm »
Brian,
Sweet, totally !!!  (sorry, been watching Nemo with my daughter).  So how low does it go?
Brian Bunge
« Reply #4 on: 18 Nov 2003, 05:00 pm »
George,
I haven't done any response measurements yet; just subjective listening.  The design calls for a natural F3 of 20Hz with a Qtc=.7.  It is extremely tight and articulate and seems to have very good extension.  I expect to be in the lower 20's without any trouble.  I hope to take some readings in the morning before I head to the shop.
Jason1
« Reply #5 on: 18 Nov 2003, 11:00 pm »
What driver are you using, and how much $?
LeonO
« Reply #6 on: 18 Nov 2003, 11:49 pm »
SWEEEET!!! :mrgreen:
That would look awesome in my room :)
Brian Bunge
« Reply #7 on: 19 Nov 2003, 02:33 am »
Jason,
The driver is also from Rythmik.  A sub like this will be $800.
theranman
« Reply #8 on: 19 Nov 2003, 08:52 pm »
Brian,
 Awesome pics! I'm glad to see you're keeping up the good work. What are the exterior dimensions again?
Ran
Brian Bunge
« Reply #9 on: 19 Nov 2003, 09:24 pm »
Thanks, Ran!
The enclosure itself is a 15" cube.  The grill will add 3/4" to the overall depth as well as another 1" or so for the amp's heatsinks.
LeonO
« Reply #10 on: 19 Nov 2003, 10:16 pm »
Brian, did you have a chance to listen to the sub together with the new Metals? :)
Brian Bunge
« Reply #11 on: 20 Nov 2003, 01:11 am »
Leon,
Yes I did and I'm extremely impressed with the entire setup.  Let's hope you are too! :)
