0 Members and 1 Guest are viewing this topic. Read 14276 times.
The TACT only has one output. So I'll have to find an interconnects that will split into 2 pairs of L/R.So Woodsyi, are you doing active bi-amping now?
It absolutely has to be a SET amp?
Couple of thoughts...Instead of SET, go with OTL amp from Atma-Sphere. On the right speakers (which I believe these will be), the Atma-Sphere sound is magically! To my ears, it has all the positive attributes one associates with SET, but is more robust at the extremes (especially the bass) and produces a more open and fast sound. A pair of used M-60's would be more than enough power and will keep you under your 3k budget.If you really have your heart set on going SET, I am playing with a modified (i.e. upgraded) pair of Audio Mirror 45 watt/channel amps that use the 6C33C output tubes. While they are still breaking in, I think they have some excellent potential (although I don't believe they will best the Atma-Sphere amps). Here is their webpage: http://www.audiomirror.com/amps.htmlGeorge
Atma-Sphere OTLs were really nice with horns. I would think they would be good with ribbon tweeter and a small midrange cone. I don't think the 4th order passive filter between the tweeter and the midrange woofer would present a tough load. What's the sensitivity of the mid/high as a unit if you decoupled the bass woofer?
Err...not sure... I need to ask Jim Salk about this. I think the specs may change a little because this is going to be the first pair of open baffle with ribbon tweeter he builds.
Why not go active crossover period? You can ask Mr. Murphy and Mr. Salk to set the parameters for a Behringer DCX2496.
