FS: Exact power Ultrapure
0 Members and 1 Guest are viewing this topic. Read 1388 times.
AVguy
« on: 18 Oct 2008, 07:43 pm »
There's a lot of AC noise coming out of your wall sockets, and that's polluting your Audio and Video signals. You need a good line filter to clean-up your power, and one that does not strangle your amplifier(s) for power. Exact Power is acknowledged as one of the leaders in the industry. Learn more about their products through the link provided above.
A very favourable review of the Ultrapure 1 from the best HT magazine in the business, Widescreen Review, appears here:
http://www.exactpower.com/assets/reviews/ExactPower_WS_UltraPure.pdf
Not only does the Ultrapure 1 filter over a much wider band, extending further down into the Audio frequency spectrum than other filters, it also balances your power.
For sale, I have two Exact Power Ultrapure 1 units. One is new and sealed in its box, and one is a used unit in perfect condition. Email me for photos.
Retail is $2000.00 US You can have the new one for only $1400.00 and the used one for $1200.00 obro
Money Order, Bank Draft, email or wire transfer preferred. If buyer wants PayPal, buyer pays fees.
Check my feedback on Audiogon under Golden_ears
Features
? Wideband Filter with Symmetrical (Dual Balanced Output) Power provides an extremely wide frequency range
? Two 500 watt symmetrical power transformers to provide maximum isolation between components.
? Three-stage approach to completely isolate your equipment from unwanted line noise and RFI.
? Custom-made, heavy-duty toroidal inductors used throughout to maximize performance, and lower the output impedance to the load.
? Ten isolated, full-contact Hubble NEMA receptacles (six are GFCI protected) (USA model)
? Input Voltage: 120 Vrms nominal
? Nominal output voltage: 120VRrms ±2%, 60Hz -1Vrms,
1 to 15 Amps
? Inputs: Standard 15A IEC receptacle
? Outputs: 6 Hubbell GFCI-protected NEMA 15-R and 4
Hubbell NEMA 15-R receptacles
? Protection: 5 separate stages of high voltage
protection systems
? Weight: 40 pounds
? Dimensions: 17" wide x 3.5" high x 14.2" deep
