XM radio question
0 Members and 1 Guest are viewing this topic. Read 1309 times.
drphoto
XM radio question
« on: 13 Oct 2008, 03:45 pm »
Lately when I try to change the channel on my XM receiver, it displays "Loading" for several minutes and then goes back to the previous station. No help @ the company website. Receiver is an elcheapo Audiovox. Any subscriber had the same problem?
thanx
Re: XM radio question
« Reply #1 on: 13 Oct 2008, 04:02 pm »
Nope.  Factory Chevy truck Delco or whatever.
Bob in St. Louis
« Reply #2 on: 13 Oct 2008, 05:49 pm »
Are you trying the "XM" site, or the AudioVox site?
drphoto
« Reply #3 on: 14 Oct 2008, 04:07 am »
Bob, tried the XM site. Didn't think about checking w/ the Avox folks.
Bob in St. Louis
« Reply #4 on: 14 Oct 2008, 11:53 am »
I'm just thinking out loud here, but.....It sounds to me more like an equipment issue than a "software" issue. Possibly a weak reception?
 I work for General Motors which has had XM in automobiles for several years now. I've never heard of your symptom happening in a factory system, but XM is transmitting 24/7/365. I would think if the problem was on their end, I'd have a line of unhappy customers telling me their XM didn't work.
Is this system in a car, or in your house?
Bob
drphoto
« Reply #5 on: 14 Oct 2008, 08:15 pm »
it's in a car. it all worked fine until about a week ago. maybe it's the unit. it WAS cheap. I replaced my stolen pioneer inno w/ it, as I didn't want to shell out the almost $300 the pioneer cost w/ the car adapter kit. I really only use it when I drive to Cincy, which isn't very often these days.
Bob in St. Louis
« Reply #6 on: 14 Oct 2008, 09:12 pm »
I'm not sure man. I did a little "Googling" on the subject and didn't find anything useful.
I'm still thinking it's either in the antenna or an actual failed head unit.
My bet is that thin delicate wire that leads to the antenna base got pinched/cut/chaffed.
Most aftermarket installers will route those wires under the rubber weatherstrip of a door to get the antenna outside. The problem with that is they've taken a thinly insulated 16 gauge (roughly) wire and bent it 180 degrees around two spot welded pieces of body panel and then pound the weatherstrip back on with their fist. The problem with that is the wires insulation got nicked on a sharp piece of spot weld. Plus, most of these installers choose to route the wire through the drivers door jamb......The door that's opened and slammed more than any other door on the car.  :roll: :duh: Or, they'll route it outside of the trunk.....The one door everybody seems to feel the need to slam the Hell out of to get closed.  After a few months moisture has "had it's way" with the copper inside, thereby leading to poor reception. When the head unit can't "lock on", it simply gives up.
- If you installed it yourself, double check your routing and check every inch of wire for any signs of damage (focusing on where the wire exits the car).
- You had this done fairly recently didn't you? If memory serves, it wasn't that long ago. If a shop did it for you, it's probably still under warranty.
- Possibly a lose or dirty connection to the back of the head unit, but not the most common cause I've seen.
- I doubt it's an XM problem. I'm confident it's either reception of failed head unit.
Bob
drphoto
« Reply #7 on: 15 Oct 2008, 12:22 am »
Thanks Bob, I'll check that antenna wire.
