Bangalley Head
0 Members and 1 Guest are viewing this topic. Read 2183 times.
JohnR
Bangalley Head
« on: 13 Oct 2008, 10:00 am »
Some shots from last weekend, on Bangalley Head.
More shots here: http://www.lostupnorth.net/shoots/0810e/
Thanks for looking :)
JohnR
ooheadsoo
Re: Bangalley Head
« Reply #1 on: 13 Oct 2008, 08:51 pm »
John, your stuff continues to inspire me.  Flash?  Which camera?
drphoto
Re: Bangalley Head
« Reply #2 on: 14 Oct 2008, 04:59 am »
getting better all the time! nice job
JohnR
Re: Bangalley Head
« Reply #3 on: 15 Oct 2008, 06:45 am »
Thanks, much appreciated :) ooheadsoo - this series is with the S5 Pro. No flash used. I've considered it, but wonder how much it would really help me (and I would have to buy an R1C1 set or something like it). I have read somewhere about people just bringing a collapsible reflector, I think I would like to try that.
byteme
Re: Bangalley Head
« Reply #4 on: 15 Oct 2008, 12:26 pm »
John, I've got one of those collapsible reflectors.  If you get one, avoid the one with the hole in the middle made to put over the front of your lens.  Its a PITA to use one the camera and if you try to use it off the camera the hole in the middle kinda messes things up.  It can be used that way and I have but you really have to be using tripod or have someone with you to hold the reflector.  They really can help though.  I think adorama sells a couple that are double sided one flat white and the other another color of your choosing to add a different hue to things.
Thankfully the one I do have didn't cost very much so it's not that big a deal.
JohnR
Re: Bangalley Head
« Reply #5 on: 16 Oct 2008, 08:57 am »
Thanks for the tip. I probably won't buy from Adorama as their postage starts at $50 for me (or is that B&H... hm...)! Hopefully I can get something locally. Does the reflector also need to be mounted on a tripod? (I have a second one but I'm not sure I want to carry it...!)
