0 Members and 1 Guest are viewing this topic. Read 9525 times.
The Salk ribbon, is a tweeter ribbon.... They use a cone for midrange reproduction. I think some of you guys are a little confused regarding imaging Dave
Quote from: flintstone on 12 Oct 2008, 03:56 pmThe Salk ribbon, is a tweeter ribbon.... They use a cone for midrange reproduction. I think some of you guys are a little confused regarding imaging DaveWhy would you say that? There are several songs I use for imaging. I close my eyes and imagine where the singers or instruments are. If I can tell where they are (or their positions are clearer in space) with one item (say, speakers) than with another item, the former has better imaging. There's not a lot to confuse one with imaging.
I think you have to 'blame' /'Thank' Nuance for that development. I believe after all the time spent on his speakerquest with funkmonkey, and Craigsub, he had pretty well settled on the original Songtowers, but wanted that little bit more. Something a little different. He spoke to Jim and Dennis regarding the swap, and they came up with the ST RT. I'm sure he'll jump in if I have it wrong. I think he's addressed what he felt were the sonic differences in prior posts.
Yeah Doug, I've done every set-up recommendation from Vmps and moved them all over the place. There are no waveguides for RM-1's and I won't ever buy another VMPS product, so I'm looking at the Salks for a variety of good reasons. I think the Songtowers fit the bill, we shall see.
So far, I think the Salks beat the RM40s in low bass, but the bass is boomy, so I'm not sure that's a plus. Otherwise, I think the RM40s best the Salks in every other category. I think the bass is so boomy on the Salks as to be unlistenable; however, I haven't been able to spend any time positioning these speakers, and I think they may take different positioning than the RM40s, but I just put the Salks in the RM40's spots.
