VSS subwoofer as a support for a component.
0 Members and 1 Guest are viewing this topic. Read 3067 times.
Brougham
« on: 11 Oct 2008, 08:41 pm »
Is it possible to use the VSS sub to support a turntable or does it vibrate too much? I am at a loss for space.
Brian Cheney
    • http://www.vmpsaudio.com
Re: VSS subwoofer as a support for a component.
« Reply #1 on: 11 Oct 2008, 11:10 pm »
The VSS can be used as a stand but with a turntable, I would suggest an intermediate damping layer.  This can be an innertube with a flat piece of MDF on top, or similar isolation.  While I would not place the TT directly on the woofer, it should be fine sitting on an isolated platform on top of the woofer.
Imperial
  • Love keeps us in the air, when we ought to fall.
« Reply #2 on: 11 Oct 2008, 11:12 pm »
What about a wall mount shelf then?
Imperial
Brian Cheney
« Reply #3 on: 11 Oct 2008, 11:56 pm »
I see no problem with a wall mount shelf.  The VSS can be used as a stand with some additional isolation, as suggested.
Brougham
« Reply #4 on: 12 Oct 2008, 12:26 am »
The isolation suggestion sounds like just the ticket.
