Quote from: Mariusz on 15 Oct 2008, 02:04 am...............but away, nice system and love the Steve's digital approach. If you are reading it Steve, I am very close to have another conversation with you.This time - all about finalizing the details and few questions.....or more like advise seeking "Q"s. aaIf you're talking about Steve from Emperical and the Off-Ramp 3, I'm going to be buying one myself. Both Chris and I thought it was significantly better than a full-modded SB3.
Quote from: woodsyi on 14 Oct 2008, 09:33 pmBalanced Power: I met the infamous Turbo. He is actually cool dude who dresses well. He had an interesting monitor design that sounded very good. Nothing extraordinary but well balance sound throughout. Would you admit that you have bias against the amps and front-end we were using? You did comment on that to me while listening ...I'm not asking to cast any shadow on comments you might make, but because Chris and I are looking to go a different direction for next year and talked all weekend about what we should use to help project a more accepted first impression. Neither of us are big tube fans, but we're both thinking we need something glowing up front so that people won't have their mind made up before sitting down.
Quote from: AB on 14 Oct 2008, 11:58 pmFor me it was just the opposite. I was more impressed with the Cirrus speakers given they were driven by the ICE amps fed by your lap top. I would love to hear them driven by something - shall we say - more refined. But seeing they sounded as good as they did, I have little doubt they will sound over the top when driven by higher quality amplification and a fancy ass source. And at their price point I would say they did sound exceptional. Thanks for saying that ... the idea we had was a "recession system" that still sounds fantastic. I just don't know if it turned people off. For example, Chris (BPT founder) is friends with Michael Fremer. They spoke literally right outside our door, Michael said he'd come in for a listen, but didn't and all I can assume is because we were too 'ghetto' for him. We did get more requests for formal reviews than I'll have any chance of accomodating, I guess that's good.Hard to know what to do in order to appeal to a value market, but not be looked down on by the rest. So honestly any input would be appreciated. We ran computer audio the Off-Ramp, into a TacT pre, into ICE amps ... does seeing an all 'digital' stack influence your opinion, should we put some tube/analog gear up front to alleviate that?
If I were to admit to having reservations about your set up (and I am not) I would say it was not the digital aspect of the front end (What's an Accuphase or Ayre CDP if not digital front ends?) but the DSP nature of the front end. I know that DSP is becoming more and more important to getting good sound out of system and room but I just don't like auditioning speakers with DSP involved. I want to hear the speakers straight from the source without any correction applied. If great speakers sound like crap then, then there is something wrong with the synergy of the system. I want to hear your speakers sounding as best as you can get them to sound and I am skeptical when I see a TACT or a Behringer in the stack. I know the Tact was used as your Dac and your crossover for the subs and that there was no FR correction used but on Sunday when I thought the system sounded different you explained you had adjusted the subs output down a few db. You were just tweaking your sound. Others move their speakers around or try different cables, you drop the subs output a bit and get the same result. Right? Right. But I want to hear the speakers not the TAct.I sat and listened happily to your and Chris' system three or four times during RMAF but if I saw an Ultramizer in your room, even I would have walked out. To answer your question whether tube amps and/or a more conventional source might make your speakers appeal to a larger audience I would say a system built to produce the best possible sound is the way to go. Do you think you could have a better sounding system using tubes and a TT? I think your set up sounded great but I would like to hear the speakers through tubes and a TT too. But that's just me.Anyway...I am curious what others think.Is adding DSP to a system a cheat or is DSP just another way to achieve system synergy? Probably a topic for a different thread.
Thanks for the feedback ... I've said the same to Chris about the TacT, and it possibly making people think we're using processing when we're not. I know you don't get enough time to explain things, and initial response is usually what they walk out with. So the people that only sit down for a song and don't ask might very well walk out thinking we're doing all sorts of EQ'ing.Sunday morning we came into the room and Chris said to me "I think we have too much bass on the monitors". I just said whatever, sounded good to me. So he made a new setting, but with xover at 50hz instead of 55hz ... and about 1 db less to the subs, then switched between them on the fly. I thought it sounded better with the lower sub setting, but I think I remember you saying it sounded better the day before. But didn't I also play two crappy tracks for you on Sunday to start? I should have known not to play tracks I hadn't heard before for somebody. Hey, you know your sub probably has a volume knob on the back too We didn't do anything with the TacT that the volume knob can't do, just saying. Didn't we also play them for you without subs? The tall ribbons though, they HAD to have full room correcting and EQ'ing to work. I think we both tried to make that clear to anyone who heard them.Are there better amps than the ICE stuff, definately! Would a TT improve on our source setup? That I'd have a harder time believing. One thing Chris and I agree on is to keep the stack of gear as visually unobtrusive as possible, a tall stack right in the middle of the image is very distracting ... so I can't see us spinning vinyl. The right tube gear though, no reason why we wouldn't give that a shot.Ultramizer, hahaha!
Also, I was really surprised at how many people would walk into a room, LOOK at the gear and just walk out, never listening to a note.
I thought the Jaton room with Operetta amps sounded great, very live. Although, I was a little put off by the open-cover amp revealing black covers to hide the secret technology which is said to produce 300 W of Class A with very little heat. I can understand being protective and what not, but I had to laugh when somebody said after leaving that room, "Ancient Chinese secret, huh?" just like the 1970s water softener commercial.
Quote from: AB on 15 Oct 2008, 05:58 amAlso, I was really surprised at how many people would walk into a room, LOOK at the gear and just walk out, never listening to a note. Two words:Body OdorBob
Quote from: Bob in St. Louis on 15 Oct 2008, 05:47 pmQuote from: AB on 15 Oct 2008, 05:58 amAlso, I was really surprised at how many people would walk into a room, LOOK at the gear and just walk out, never listening to a note. Two words:Body OdorBob Man, we were in the linkwitz room and someone cleared the place...most awful moment of the show for me....
Rethm Saadhana: I was really looking forward to these speakers but something was off in the room when I was there. I must have been the room as the bass was flabby. With mushy bass, the mids and highs just don't click in. I would love to have heard these in a better room. They are not as big as I envisioned.
Ha, not it OUR room. Does this guy look like he smells?
Quote from: TurboFC3S on 15 Oct 2008, 05:58 pmHa, not it OUR room. Does this guy look like he smells?Most definitely not Ryan. No way there's any bad smells in that room. Especially when you're standing between about 13 running feet of Sharper Image Ionic Air Purifiers.No way it could smell. {My apologies Chris. Please don't be mad at me.}Bob
