Here is a clean Pilot Tube receiver model R-303. As you can see from the pictures, it does not have the wood chassis that is was designed for. It produces 30 watts per channel via a pair of EL84 tubes.
At the moment, there is a pair of Mullard EL84s and a pair of Telefunken EL84s in it.
It does work but has not been hooked up to a system in some time.
Just the tubes and the iron must be desired by someone. It will be sold as-is.
All the following tubes are currently in the amp and will come with it:
- Telefunken EL84 x2 pieces
- Mullard EL84 x2 pieces
- Telefunken 12AX7 x3 pieces
- Mullard 12AX7 x1 piece
- Mullard 12AT7 x1 piece
- Mullard 6EW6 x3 pieces
- Mullard 6BE6 x1 piece
- Telefunken ECC85/6AQ8 x1 piece
- 12AU7 - "Made in Great Britin" x1 piece
- EC906C4 - "Made in Italy" x1 piece
Please make offers via email at
[email protected]
