0 Members and 1 Guest are viewing this topic. Read 26394 times.
Quote from: woodsyi on 13 Oct 2008, 02:36 pm As for jitter reduction, I don't know why someone doesn't think Wayne is doing something about it. What do you think all these different PS's and isolations are for? I also have a modified SB3 with a reclocker and it resolves more details than my Statement SB2 but this may also have something to do with my 3k DAC that I use. I think there are different ways to reduce jitter. Wayne has gone with prevention rather than reclocking before a DAC. I like the reclocking idea but Wayne may have cleaned up so much that there may not be that much improvement even if reclocking is added in the future. Can jitter be reduced via power supply mods? My limited knowledge on this subject has led me to believe that jitter is caused by timing imperfections in the digital stream that can only be reduced by modifications to the clock. I'm not trying to be a smart a** here, I'm simply asking a question that I don't know the answer to.thanks
The point I was trying to make was that PSU noise causes jitter in digital circuitry.
Anything with "SqueezeBox" in the name is going to draw major criticisms with such a high price tag.By not having "SqueezeBox" in the name, people will look at it for its features and functionality, rather than think of it as a ridiculously expensive SB.George
I'll leave out the comments about whether or not a $6k Squeezebox makes any sense. If you can sell them, then more power to you.The only question I have is why wouldn't you begin with the much better sounding Transporter for such a product?
Quote from: JEaton on 15 Oct 2008, 10:06 pmI'll leave out the comments about whether or not a $6k Squeezebox makes any sense. If you can sell them, then more power to you.The only question I have is why wouldn't you begin with the much better sounding Transporter for such a product?Because then you'd have an $8000 squeezebox?
Isn't this effectively a $5700 power supply for a $300 digital device? And it doesn't re-clock? Should sell well in this economy.
