12V Input
0 Members and 1 Guest are viewing this topic. Read 1777 times.
ashtarul
12V Input
« on: 6 Oct 2008, 02:34 pm »
Hi,
Please excuse my ignorance as this may be a stupid question to some :oops:
How do you use/set up the 12V input?
Ash
  • The Demo is Everything!
    • http://www.bryston.com
Re: 12V Input
« Reply #1 on: 6 Oct 2008, 07:33 pm »
Hi,
Ash
Hi Ash,
On the back of your BP26 Power Supply (MPS-2) there are four 12 volt trigger outputs.  Use any twin lead wire (size is not important because it is very low voltage {22 gauge is fine}) and connect one end to the MPS-2 and the other end to the 12 volt trigger 'in' on the 14B.
They both have plugs that pullout and you insert the bare wire and screw it down to secure the connection.
Make sure the TRIGGER switch on the back of the 14B is set to REMOTE (not Local) and make sure the preamp/amp is on. Then when you switch on/off the preamp the amp will follow.
Don't think I have forgotten anything?
james
ashtarul
Re: 12V Input
« Reply #2 on: 8 Oct 2008, 01:35 am »
Ok. I will give it a try. Thanks James
ashtarul
Re: 12V Input
« Reply #3 on: 11 Oct 2008, 08:34 am »
It worked, thanks. Also I just realised the instructions are in the manual... :duh:
