3B SST, help and info appreciated.
0 Members and 1 Guest are viewing this topic. Read 1578 times.
chevvies
« on: 5 Oct 2008, 09:49 am »
I don't own a Bryston product, but like the sound of the 3B SST, and I find the warranty commendable in this day and age.
My speakers are ATC SCM11, would this be a good match? I currently use an ICE power set up and was considering more of the same but I am drawn to the Bryston name having been aware of it for years via recording studios and hi-fi circles.
Budget constraints and the fact I am in England limit my chances of ownership, I shall keep looking for offers and used units.
Is the 'pro' version just cosmetically different?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 3B SST, help and info appreciated.
« Reply #1 on: 5 Oct 2008, 12:48 pm »
Hi Chevvies.
The  Pro series is available in Black 19 inch rack mount faceplate only. http://bryston.ca/14bsstpro_m.html
The consumer C- Series is available with the C-Series cosmetics - in silver or black and in 19 inch faceplate or 17 inch faceplate.
http://bryston.ca/14bsst_m.html
The Pro series also has volume controls in the circuit path on each channel - the consumer C-Series does not.
I usually recommend the C-Series if you want the simplest cleanest signal path and the Pro if you need the volume control on each channel.
vegasdave
« Reply #2 on: 6 Oct 2008, 01:10 am »
I hope James doesn't mind, but if you buy from a pro audio dealer, you can get a new unit at a great price.
