What it takes to make a fantastic tube amplifier
Niteshade
    • Niteshade Audio
« on: 1 Oct 2008, 07:40 pm »
What it takes to make a fantastic tube amplifier:
1. Point to point wiring
2. Low parts count
3. Efficient tube loading
4. Strategic parts placement to reduce noise, dissipate heat
5. Effective internal ground system
6. A circuit made to be easily modified/updated/repaired
7. High construction standards essential for safe, reliable operation
8. Post-assembly tests to insure components are working at peak efficiency
9. The listening test: If we don't like it, you won't get it.
10. Customer ideas and thoughts. (Yes, they have a BIG role in our design & assembly processes!)
There it is- the master list of ingredients.
Please look at our Audiogon feedback score:
http://cgi.audiogon.com/cgi-bin/auc.pl?ampstube&1221268222
We frequently sell products at huge discounts as a means of advertising. Take advantage of them!
****Don't forget to check out the web site.****
