MAYA SITE LINK
AUDFILE74
MAYA SITE LINK
« on: 1 Oct 2008, 02:19 am »
Hello Hugh!, i was wondering when there would be a link on www.aksaonline.com for the new maya amps? also , for some reason, i never get the soraya link to work. thanks
AKSA
Re: MAYA SITE LINK
« Reply #1 on: 1 Oct 2008, 08:44 am »
I have renamed the Maya the Soraya Mk II, so that I don't have to remachine very expensive front panels!
The Soraya webpage does not work because it's not yet done.  I spent an entire day last week doing the Lifeforce 100 and the Hologram III power supply, tidying up the pricelist, and will need to take a deep breath next week to do the Soraya.
The amp is certainly available, no question, but I'm involved in so many things at present including a new Class A hybrid that I've paced myself out a little....  forgive me.....
Hugh
« Last Edit: 1 Oct 2008, 11:30 pm by AKSA »
whubbard
Re: MAYA SITE LINK
« Reply #2 on: 1 Oct 2008, 01:01 pm »
Hugh,
I'm not sure if you still have it, but the HTML code I sent you a while ago should help you fix up all the links for the time being. I think you only have to add the links for the Hologram III.
-West
AKSA
Re: MAYA SITE LINK
« Reply #3 on: 1 Oct 2008, 11:00 pm »
West,
Your intentions are clearly altruistic, for which I thank you profusely, but that vestigial reptilian part of my brain which should have developed along digital lines has, sadly, regressed.  I now spend most of my nights roaming the streets eating rats, dreaming of a fully analog world, sad but true......   :lol: :lol:
I have about as much idea of how to use your code as a garden snail has about painting a Monet...... :duh:
I spent the afternoon yesterday at a small factory which specialises in surface mount repair and manufacture.  I came away very impressed.  This is brilliant, clever technology, and I will be using it to assist with the drudgery of hand assembly of my modules.  My top quality modules I will continue to make myself in my workshop, but starting with some lower power modules I hope to use for a HT amp, I will increasingly use smd.  After set up costs are paid, it's cheap, so cheap, and highly reliable if design is well done.  I tried my hand at some smd pcb design recently, and the EE at the factory was very impressed, and said it was commercial quality, and well designed from a layout standpoint.  So there's a skill I've picked up OK, a good sign....
The website issue doesn't worry me, I will fix the links soon anyway, I spent a day last week updating the SB3 power supply and Lifeforce 100 links, and remarkably, they are now up and running perfectly.
Hugh
whubbard
Re: MAYA SITE LINK
« Reply #4 on: 2 Oct 2008, 01:34 am »
Hugh,
Inserting the code wouldn't be difficult in theory, but since you have never worked with the bare HTML, I very much understand. If you were to look at the code from your website it would probably be a bit daunting.
Also, do you feel that the SMD resistors will sound as good as the ones you use now? Do you think it could affect performance?
-West
AKSA
Re: MAYA SITE LINK
« Reply #5 on: 2 Oct 2008, 04:37 am »
West,
I reckon smds, particularly the 1210 half watt version I use, will sound just as good and arguably, because of lower inductance, they might even sound better.
Hugh
AUDFILE74
Re: MAYA SITE LINK
« Reply #6 on: 25 Oct 2008, 04:02 am »
THANKS FOR GETTING THE SORAYA PORTION OF THE SITE WORKING HUGH! :thumb:
AKSA
Re: MAYA SITE LINK
« Reply #7 on: 25 Oct 2008, 04:05 am »
AF74,
It was a pleasure, I almost enjoyed it, and it all went very smoothly!!
I was surprised.....  my reptilian brain must be evolving..... :lol: :lol:
Hugh
AUDFILE74
Re: MAYA SITE LINK
« Reply #8 on: 26 Oct 2008, 03:59 am »
you and your unique humility hugh. i don't know (and don't want to know) what we'd do without you. noew off i go to see if i can make my back remember happier times :cry: night all
