0 Members and 1 Guest are viewing this topic. Read 9769 times.
http://www.diffractionbegone.com/index.htmlI gather they offer a VSA fit.
Do you run with or without grills? Can you describe the improvement in sound?
Quote from: es347 on 11 Sep 2009, 08:55 pmDo you run with or without grills? Can you describe the improvement in sound?The imaging focus improved. Small details were less ambiguous, more clearly difined. The bass also seemed to improve in definition, perhaps the harmonics from the upper frequencies? It always impresses me when an improvement in one area effects something on the other end.
Quote from: SoundsGood on 11 Sep 2009, 10:26 pmQuote from: es347 on 11 Sep 2009, 08:55 pmDo you run with or without grills? Can you describe the improvement in sound?The imaging focus improved. Small details were less ambiguous, more clearly difined. The bass also seemed to improve in definition, perhaps the harmonics from the upper frequencies? It always impresses me when an improvement in one area effects something on the other end.Allow the old man to chime in here. Sounds like an improvement to me. Good for you, SoundsGood, for discovering this.
Quote from: jimdgoulding on 11 Sep 2009, 11:43 pmQuote from: SoundsGood on 11 Sep 2009, 10:26 pmQuote from: es347 on 11 Sep 2009, 08:55 pmDo you run with or without grills? Can you describe the improvement in sound?The imaging focus improved. Small details were less ambiguous, more clearly difined. The bass also seemed to improve in definition, perhaps the harmonics from the upper frequencies? It always impresses me when an improvement in one area effects something on the other end.Allow the old man to chime in here. Sounds like an improvement to me. Good for you, SoundsGood, for discovering this. Your product is probably the way to go after it's all said and done. I just wanted to try it out for myself and it definitely works. It is certainly one of the most cost effective improvements one can do and for $49 bucks you can't go wrong.
I don't doubt what you are hearing but the idea of sticking something on that beautiful gloss black finish makes me a bit light headed
What I have in mind could be cut by you to fit inside of your grilles if you use VR4jr's.
