Recommend Wifi Digital Frame
jkelly
« on: 27 Aug 2008, 11:48 pm »
Can someone recommend a wifi digital frame?
What system works better - syncing to an on-line
gallery or emailing to it? Or...
thanks,
Jeff
byteme
Re: Recommend Wifi Digital Frame
« Reply #1 on: 22 Sep 2008, 12:13 am »
After looking to replace a digital frame that pooped out and seeing how much a decent one that was bigger than 7" cost I went another route.  Bought a used PC on ebay for $60 and picked up a 22" widescreen monitor.  The used PC is connected wirelessly to my main PC in the office - I dump pictures down to it that I want and run a slideshow using iView media pro.  Total cost just over $200 which was about the same as a good 14" all in one unit.
This won't work for everyone but people always comment on how awesome it looks!
