GREAT info that you sent with the ribbon element replacement
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
WOW Al. That was a lot of great information on that cd you sent. I finally got around to looking at it last night. I really really appreciate it. I wish I would have had something like that when I went to build my OB7's.  You really take care of your customers!
I haven't done the replacement yet, probably will do that this weekend.
Best regards.
Tony
Hank
Re: GREAT info that you sent with the ribbon element replacement
« Reply #1 on: 28 Aug 2008, 06:13 pm »
TRADERXFAN
    • GALLERY
« Reply #2 on: 28 Aug 2008, 06:50 pm »
-sorry Hank, was my post confusing?
I bought a pair fo ob2x 2nd hand. I had to replace a ribbon element and ordered from Al. He included a cd with a lot of information useful for a diy speaker project, such as veneering, which he sends out with his kits. Just wanted to say that it was really good information that would have been helpful when I was building my ob7's.
Hank
« Reply #3 on: 29 Aug 2008, 12:12 pm »
Thanks, I was guessing that the CD had ribbon replacement instructions, but your explanation says it contains lots of other useful info as well.
Way to go, Al! :thumb:
« Last Edit: 2 Sep 2008, 11:48 am by Hank »
