2 HDMI sources, one monitor -- how to do it?
0 Members and 1 Guest are viewing this topic. Read 1561 times.
jrebman
« on: 27 Aug 2008, 03:21 pm »
Simple enough question, but I know zilch about anything video, so how would I connect the DVI (then converted to HDMI) from my Mac Mini and the output of my Oppo player to the same monitor?  Only need one at a time and I suspect that an HDMI switch of some kind is needed, but I have no idea what to look for in terms of features, etc., and how much I should spend.
The monitor is a 27" or 28" Toshiba LCD TV.
Thanks for any advice.
-- Jim
mcullinan
Re: 2 HDMI sources, one monitor -- how to do it?
« Reply #1 on: 27 Aug 2008, 03:42 pm »
Jim,
This is what you need. I have to get one too, eventually once I get my Bluray player and manroom Flatscreen. :)
There are others out there, but this is Oppo!
http://www.oppodigital.com/hm31/
Mike
WGH
« Reply #2 on: 27 Aug 2008, 03:53 pm »
Monoprice has a HDMI switcher with remote for $20.90
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110
I use a component switcher from them. It works perfectly.
Wayne
jrebman
« Reply #3 on: 27 Aug 2008, 04:24 pm »
Mike and Wayne, thanks -- this is about what I figured but great to have a couple of models to look at.
Thanks again,
Jim
whubbard
« Reply #4 on: 27 Aug 2008, 04:38 pm »
Well, I probably wouldn't spend $100 on an HDMI switcher.  Most of these won't affect the picture at all, so it's not worth spending the extra money.
My suggestion would be:
Rosewill 3 to 1 Has Remote. $39 HDMI 1.3 Good Quality
The 1.3 is fairly important, and the price is right on this switcher.
-West
jrebman
« Reply #5 on: 27 Aug 2008, 05:23 pm »
West,
Thanks for the additional choice.
-- Jim
rydenfan
« Reply #6 on: 27 Aug 2008, 05:42 pm »
I own the Oppo switcher and it works great. The inputs actually go in priority so if the device pulgged into input 1 is not powered on but the device in input 2 is, then it will automatically switch to that input. A cool feature for sure.
jrebman
« Reply #7 on: 27 Aug 2008, 08:08 pm »
And what if you don't have a 3rd input?  Will it skip that one in the rotation?
Jim
rydenfan
« Reply #8 on: 27 Aug 2008, 08:11 pm »
Yup.
I used all three when I used it though.
