Industry Circles
Bryston Limited
Bryston 10B Electronic Crossover
0 Members and 1 Guest are viewing this topic. Read 1685 times.
Facilitator
The Demo is Everything!
ยป
26 Aug 2008, 11:44 am »
Hi All,
Nice feedback from one of our dealers on the engineering quality of our 10B Electronic Crossover.
RE:Bryston 10B-LR Balanced
Tesuque [
[email protected]
Sent: Mon 8/25/2008 7:49 PM
To: Bryston
Hi James...
I took some measurements of my custom modified Bryston 10B electronic crossover you just shipped back to me.
With the 10B on the bench, I sent Pink Noise from Smaart into each channel. I then measured each channel Low and High outputs separately, and saved the traces. The attached image shows the Left channel, both Low and High traces.
I am stunned with the quality of your engineering!
The cursor is as-close as I was able to position it to the crossover point.
When I display both channels, I cannot tell one from the other - the traces exactly overlap. I suppose this speaks to the great care you take in matching components.
It is astonishing.
Thanks.
Bo Putnam
SOUNDsupport
Half Moon Bay, CA
Industry Circles
Bryston Limited
