0 Members and 1 Guest are viewing this topic. Read 285568 times.
We will be at AXPONA powering a potentially record breaking surround sound system! Details here:https://www.audiocircle.com/index.php?topic=163293.0
Check out our massive pre-summer sale!https://myemail.constantcontact.com/-enter-subject-here-.html?soid=1101188089143&aid=FU-pLlkxB6c#Sound #Stereo #MEGAschino #DAC #DACDAC #CherryDACDAC #CherryAmp #CherryMaraschino #CherryMEGA #MaraschinoCherry #SurroundSound #Audio #HomeAudio #Amplifiers #DigitalAmpCo #HighEndAudio #miniCherry #Cherry5ch #cherry5 #5CHerry #4CHerry #3CHerry #2CHerry #HomeTheater #ExtremeAudio
Shunyata Venom HC power cord
I dont think you should base your final conclusions on such a budget PC. Give a true audiophile PC a try like Petes Triode Wire Labs then draw conclusions. Just saying...........
Nick 77.....My thought is that the Shunyata is a $300 wire....the Triodes seem to run anywhere from $500-1200...I'm thinking that from an overall "sound of my system" standpoint, I'd be much better off to spend the $$$ on the DACDAC or the new preamp when it comes out
Tommy,I'm glad that the preamp is still in the works....Going with the analog outputs is a good decision...otherwise, its more difficult to connect to a sub. Would also suggest, if possible, to have the voltage output of the balanced and the RCAs be the same...why....because assume that the balanced outputs are 4v and i'm running those to my 2Cherry (which I absolutely love)....and then assume the RCA outputs are 2v and I'm running those to my sub....even though the sub has an input gain control...getting the overall balance between the mains and the sub is much easier if the output voltages match. (or if it is simpler, maybe just go with double balanced outputs and include the neutrik balanced/rca adapters)I hope this ship hasn't already sailed...but maybe one pair of analog inputs should be included for all the turntable/analog people....One final thing....if possible, please offer a remote...not having one will likely turn away customers....why...because those of us that use a preamp probably have a number of things input into the preamp and we want it to be master control.Thanks for listening.
Ron,You’re on. ALL OF IT !! Thanks (:-Tommy O
