AmpDesigner 333I like your philosophy and hope you will succeed in your creative venture! And when you do, don't forget that customer service is one of the pillars to a successful audio business! Krell started as a backyard project to beat the Big Boys and succeeded to become one of the most successful audio brands but they forgot about their customers once they tasted the dizzy heights of success! I had an experience with their customer service and speak from the perspective of my experience. I know how hard it is to convince the consumer that you have a great product in hand, beyond the marketing hyperbole!Best RegardsDennis
Tommy, it's always enriching to see someone thrive. And looking back as you suggested, really brings it home. Nice work and be proud.
What.... ....does Digital Amplifier Company consider reasonable or acceptable in Class-D amplifiers?
The reverse also works, so if you know SNR at 1W, you can calculate it for rated power. Almost every amp manufacturer states SNR at rated power, by the way. Thanks.
This weekend is the last one for our new Kickstarter. Time to get involved if you haven't already. Our backers provide the funds for new product development and get rewarded generously as a result.Here's the link (please help us spread the word by posting this link on social media):http://kck.st/2CH4sLBWe also added a special new reward today. It's an "only one available" pair of amps. See if you can spot it (:Thanks as always!
SNR at 1W can be calculated from SNR at rated power. This is not just for Cherry Amplifier (R) products, but for any amplifier.If we know the signal level and the SNR, we can calculate the noise level. This is typically A-weighted, by the way, but not important to the math....SNR is the ratio of signal to noise, or signal/noise. These are voltage levels. Units must match, and we use volts. SNR = 20 * log(signal/noise). Since there is more signal than noise, SNR is positive. If it were noise/signal, the result would be negative, due to the log function.We start by reversing the log function to get the actual ratio in straight scalar units (no units, actually). So, we're "un-doing the dB", going from exponential scale to linear scale.Let's say SNR is 120dB (MEGAschino, Maraschino). This means 6 = log (x), x being SNR as a linear scalar. 10^6 is 1,000,000. So, if the signal is 1V, the noise would be 1/1,000,000 V, or 1uV.Let's also say the rated power is 400W into 4 ohms (KING Maraschino). Power is V^2/R in this case, so V = sqrt(1600V^2) = 40V. So, in this case, noise is 40uV.Now, what is it at 1W (into 4 ohms)? Well, we know the noise voltage, and 1W is sqrt(4V^2) = 2V, so SNR = 20 * (2V/40uV) = 94dB.The reverse also works, so if you know SNR at 1W, you can calculate it for rated power. Almost every amp manufacturer states SNR at rated power, by the way. Thanks.-Tommy O
SNR calculation. Easy and fast.400 watts/4 Ohms -> SNR: 120dB. V=40vwith 1 watts/4 Ohms V=2v -> 120dB - 20log(40v/2v) = 120dB - 26dB = 94 dBto compare1 watts/8 Ohms -> 91 dBWith class AB, 91 dB is very good. With class D is only good, I think.
I have nothing against this amplifier. For example, the efficiency of 95% giving so much power is an engineering prodigy.The problem is in the other brands that buy modules designed by others and spoil the specifications and not by little.And then there are revisions in Stereophile and they are silent in the face of the obvious.
We are discussing a review with Stereophile, but since we don't advertise there, it might be a while. Thank for your kind post.
