0 Members and 1 Guest are viewing this topic. Read 283188 times.
I'd like to know if anyone is using unbalanced inputs and a "ground cheater plug" to eliminate noise..
Quote from: AmpDesigner333 on 2 Sep 2008, 03:52 amI'd like to know if anyone is using unbalanced inputs and a "ground cheater plug" to eliminate noise..I would hope that no one, who cares about the safety of others, would publically admit to such.You might well minimize ground loop induced noise/hum, but give up whatever benefits you accrue via balanced inputs. It is an unnecessary choice. It it also a substantial violation of US/Canada electrical codes. There is no such thing as a 'cheater' plug, There ARE plugs whose intended use is to provide a grounded outlet to a nominally ungrounded receptacle, via the receptacle's center center screw which is tied via the receptacles strap to a grounded box.This might be appropriate for alternative solutions -http://www.jensen-transformers.com/an/an003.pdfFWIW,Paul
on this page there is a picture with the link "http://www.digitalamp.com/Picture%203619.jpg". This picture does not show up. Also if I click on the link to go to that product page http://www.digitalamp.com/4800a_amp1.htm the same picture does not show up, while the other one (of the two pics) does. This happens on both the Chrome and Firefox browsers so I think it's safe to say the file is missing. If you delete the cache in your browser (under options) you will probably see the same thing I am seeing.I would recommend you pay someone who knows how to setup a "Joomla" website. Very professional and less expensive than having one built from scratch. You may be able to buy a Joomla Template and set it up yourself.Good luck with your biz.cheers, -Brad-update: I downloaded one of your "small" pics. It was 1600x1200 pixels and 700K bytes in size! This would be OK for an expanded display after clicking on the small image. But you can reduce these images to 12% (to 20K in size) for the initial pic on your products page.
We received a question about damping factor this week. Both the DAC4800A and Cherry were tested for this at 1KHz, which is higher than normal for a damping factor test. Into 8 ohms, it measures around 200 (Rload/Rout). We plan to test at 100Hz and post the result here...There has been some controversy regarding the real meaning of damping factor, however. Tube amps are known for their sweet sound but usually have a low damping factor due to high output impedance. We believe the natural open loop performance of the amp comes into play as damping factor lowers. In most cases this occurs as frequency rises. With good power supply design and strong output stages, damping factor can mean less to the sound of an amp. Once again, the proof is in the pudding, so there's no substitute for listening.Looking for some commentary about this subject...
Please take a moment and sign up for our newsletter. We have one coming out very soon (this weekend?). Here's the link:http://www.digitalamp.com/news.htm
Tommy or jhm731,Can you post a clear picture of the front and rear? I can't get what it looks like from any online photos. Looks like a lot of LEDs on the front. Can they be shut off?Thanks!!Rich
This amplifier is also a "green" product since it consumes less than 30W when "quiet" and less than 5W in standby mode.
Quote from: AmpDesigner333 on 6 Sep 2008, 10:02 pmPlease take a moment and sign up for our newsletter. We have one coming out very soon (this weekend?). Here's the link:http://www.digitalamp.com/news.htmThe newsletter went out today, so please send me a private message if you signed up but didn't receive it. Thanks.
Tommy,Can you elaborate on this:QuoteThis amplifier is also a "green" product since it consumes less than 30W when "quiet" and less than 5W in standby mode.Is it better to: A) Leave the amp powered on 24/7 in "quiet" mode? B) Leave the amp powered on 24/7 and switch into standy mode when not listening? C) Power on/off for each listening session?Some amps work fine powered on/off for each session, while others benefit from being left on. Where does your amp fit into this?-jim
Tommy,How does one operate the DAC4800A in bridged mode?-jim
