0 Members and 1 Guest are viewing this topic. Read 28508 times.
OK, here are my recommended crossover options.Each channel is a Lowther PM6A or DX2 full range driver with two Eminence Alpha 15A woofers wired in parallel.Active Crossover SettingsLow Pass - 200 Hz 2nd order Linkwitz-RileyHig Pass - 400 Hz 2nd order Linkwitz-RileyPassive Crossover Sizing (classic 2nd order circuit configuration)Zobel circuit across the woofers Mills 4 ohm resistor Solen 30 uFLow Pass ERSE 14 ga Super Q 4.7 mH in series with the drivers Solen 130 uF in parallel with the driversHigh Pass Solen 27 uF in series with the drivers ERSE 14 ga Super Q 5.6 mH in parallel with the drivershttp://www.erseaudio.com/Products/14-AWG-1-63mmhttp://www.partsexpress.com/solen-metallized-polypropylene-capacitors.cfmThese would be my starting crossover values and I would tweak them by ear.Hope that helps,Martin
I don't think Martin would mind if I reply to your question. What your sketch shows is low-pass filters on both the woofs and the Lowther. You need to switch the crossover parts on the high-pass, so that the capacitor is in series, and the inductor is in paralled with the driver load. - Pat EDIT: You seem to have added another cap on the low-pass, too, as well as adding a resistor. Not really sure of what these are intended to do.
Maybe this will do do. I am not positive on the Zobel. I will be using a DX4, so I am not sure if I need to pad down or notch the DX4.http://picasaweb.google.com/lh/photo/VDdA4h98MPWdU0F9Be3W2g?feat=directlink
Quote from: T-BAG on 23 Jan 2009, 07:50 pmMaybe this will do do. I am not positive on the Zobel. I will be using a DX4, so I am not sure if I need to pad down or notch the DX4.http://picasaweb.google.com/lh/photo/VDdA4h98MPWdU0F9Be3W2g?feat=directlinkFor the Zobel circuit, the 30 uF cap and the 4 ohm resistor need to be in series across the woofers. Your sketch shows them in parallel across the woofers.A DX4 will definitely need some attenuation to match the parallel pair of Alpha 15A woofer's outputs.
Totally unsure of tweeter location, but to recycle these panels, I need to use existing holes.
