12" Passive Radiator??
penderaudio
« on: 8 Aug 2008, 01:59 pm »
Hey Kevin,
I'm working on a new project and wondering if you have finished, or are still going to have a 12" passive radiator for the Shiva-X?  I have a bunch of 15" PVC that I want to fill with lots of Shiva-X's. If not do you know of a Passive radiator that will work with the Shiva-X?
Thanks Penderaudio :P
Kevin Haskins
Re: 12" Passive Radiator??
« Reply #1 on: 12 Aug 2008, 01:43 am »
I have the PR-15 in stock which should be the ideal combination with the Shiva.   It will be $85 and I'll have more details later this week once I get unburied.
penderaudio
« Reply #2 on: 12 Aug 2008, 11:38 am »
Cool sounds good. I wasn't thinking that I could use the 15" P-R with the 12" sub but that makes sense now! No big hurry on the specs, this project is a month or two out yet.
Thanks Kevin.
P.S. those 4 XJ-15's really sound great in my dipole setup.
