0 Members and 1 Guest are viewing this topic. Read 4505 times.
Do you know the voltage applied to the LED, or have a multimeter to measure it? There are a lot of LEDs out there. Digikey lists more than 8000, more than 760 of which are red. Through-hole mount gets us down to 260+, but next we need a voltage. The brightness range is 1mcd to 10,000mcd, so we can certainly find something bright enough. Do you have a link or part number for the Radioshack ones you tried that weren't bright enough? That would give a starting point. That info plus the voltage should narrow it down to a specific recommendation.
Hey! Set your meter to DC and with a range of about 10V... depending on your meter the range could be different on your meter. But most likely that the V on this won't be more than 5V. You could take measure at the solder connections or at LED's legs. If the meter move backward or won't move just reverse it. After you know the V than you could select the right LED with the right V for it. BTW... I bought an ultra bright Blue LED from Radio Shack to replace the green one that came with my DAC kit and it is bright! It will lite up the darken room with a cool blue glow. I forgot the mcd on this one. I'm pretty sure that one of those LED at Radio Shack should be OK in your Nak. An another place that I know of is...http://www.partsexpress.com/webpage.cfm?webpage_id=3&CATID=48&ObjectGroup_ID=554http://www.partsexpress.com/webpage.cfm?webpage_id=3&CATID=41&ObjectGroup_ID=292 But I still think one of the Radio Shack would do.... so you won't have to pay for shipping for just one LED. Just pick on with a bit more V rated than what on the Nak. Good luck. Oh! BTW... this is the Nak deck that flip the tape out for auto reverse right?Take care,Buddy
.... Thanks! I will check out the deck tomorrow for voltage! Yep! That is the deck that"flips" the cassette around for auto reverse! Cool! BTW..if I measure at the LED legs...won't I get 0 volts, being the LED is "gone".."dead" Thanks, Huck
A few links that might help.... http://www.naks.com/http://www.eslabs.com/nakamichi.htmGood luck.... (a CR-7A owner)
Quote from: Huck on 2 Aug 2008, 12:10 am.... Thanks! I will check out the deck tomorrow for voltage! Yep! That is the deck that"flips" the cassette around for auto reverse! Cool! BTW..if I measure at the LED legs...won't I get 0 volts, being the LED is "gone".."dead" Thanks, HuckHey! Those legs still connected so you will could still get V reading from them. But if you don't get any V reading than there is more problem. Oh! And of course you could change LED to other color if you like. BTW... here is my Nak....http://www.audiocircle.com/index.php?topic=51721.0 .... the Mother of all Nak. Take care,Buddy
Quote from: SET Man on 2 Aug 2008, 01:07 amQuote from: Huck on 2 Aug 2008, 12:10 am.... Thanks! I will check out the deck tomorrow for voltage! Yep! That is the deck that"flips" the cassette around for auto reverse! Cool! BTW..if I measure at the LED legs...won't I get 0 volts, being the LED is "gone".."dead" Thanks, HuckHey! Those legs still connected so you will could still get V reading from them. But if you don't get any V reading than there is more problem. Oh! And of course you could change LED to other color if you like. BTW... here is my Nak....http://www.audiocircle.com/index.php?topic=51721.0 .... the Mother of all Nak. Take care,Buddy Thanks! I measured again and I got 30 volts d.c. again! I sent an e-mail to ESL and apparantely this LED is not the original! Turns out the o.p. was a 12 volt lamp!! Thanks for all those that tried to help!! Huck
