0 Members and 1 Guest are viewing this topic. Read 8024 times.
I'd say spend most of your budget on a great cartridge. A great cartridge on a decent player will sound better than more equally priced table/ cartridge.
I'd say spend most of your budget on a great cartridge. A great cartridge on a decent player will sound better than more equally priced table/ cartridge. I had a Blue point a while back. While it was good for the money I was never thrilled by it. Got a (used) Benz M2 wood body and the air and bass was astounding. I never thought I could get such satisfying bass out of vinyl, and the only thing that changed was the cartridge.
ANy thoughts on this table?http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=200241877168&ssPageName=STRK:MEWA:IT&ih=010
Yeah- I suspect that turnatble is going to go for a lot more.Got it on regulating a tt motor...so in any turntable i look at (possibly with the exception of a technics 1200) i should also start thinking of adding this.
Quote from: pgastone on 1 Aug 2008, 01:41 pmANy thoughts on this table?http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=200241877168&ssPageName=STRK:MEWA:IT&ih=010Buy it only with the intention to get the VPI SDS....unregulated (any) drive mechanism is rarely a step in the right direction with vinyl. 25 years of CD/Redbook have taught us all a few things to expect....among them, unwavering pitch (something a TT, even with a massive platter, cannot get right without a regulated speed mechanism).But, when you add it in...it takes you out of your budget (waaay out)I'm not a musician, nor was blessed/cursed with perfect pitch...but, the 'wow' induced problems of unregulated motor drives on TT's grinds on me now.Enjoy - John
Quote from: pgastone on 1 Aug 2008, 03:24 pmYou can get belt drive decks with good enough speed regulation (as long as you're not blessed/cursed with perfect pitch)....but they tend to be > US$2000 (more than your budget as you stated)unless you're handy and can DIY something.JohnThe Music Hall and Pro-Ject belt driven TT's either come with speed control or can be added via the Speed box for $120.00. I'm sure there's one in ether's line that will definitely fit your budget.Ric
