Goldpoint Stepped Attenuators - SOLD
0 Members and 1 Guest are viewing this topic. Read 6053 times.
mgalusha
« on: 23 Jul 2008, 01:41 am »
Going through my stuff I have discovered I have entirely too many Goldpoint attenuators.
First up is a 6 channel Mini-V series attenuator using SMD resistors, 10K model. This is brand new, never installed, never soldered. Goldpoint sells these for $350. I am asking $300 as it is new. I purchased this for use as a 6 channel volume control for my DCX2496 but took another path. This is just the ticket for anyone using a DCX2496 that doesn't want to do digital attenuation while using the digital input.
I also have two Goldpoint "Mini-H" shunt attenuators. These are no longer offered by Goldpoint and are somewhat like a ladder attenuator but only one resistor is changed for each position and not two. The advantage of a shunt attenuator is that there are only two resistors in the signal path at any time, one constant value in/out resistor and the other the shunt to ground.
One of these is built with Holco resistors for all the shunts with a Dale-Vishay I/O resistor of 50K. $100.00
The second is built with Dale-Vishay resistors in all positions with an I/O resistor of 43K. $100.00
Both work perfectly but the buyer needs to be aware that in some circuits they can cause a small popping noise. This can be addressed by adding a high value resistor from input to ground to ensure a constant connection while it switches.
Prefer PayPal but will accept check (must clear). Add 3% for PP fee. Will charge actual shipping via USPS, should be very cheap as the attenuators are not large or heavy.
Mike
« Last Edit: 21 Sep 2009, 12:50 am by mgalusha »
face
Re: Goldpoint Stepped Attenuators
« Reply #1 on: 23 Oct 2008, 01:43 am »
Either shunt attenuator still avail?
